I know that this sounds silly but I'll ask anyway. We are installing a new grill on my 62. The entire front end has been replaced and is now about done. The grill has a bowed design. Does the bowed edge face out or inward? Seems to look right facing out toward the opening but doesn't fit quite right on the inside mounting. We are in the final stages! Thanks for the help folks, the car looks factastic to me.
Thanks much Paul. That will make a difference. I don't think the mounting standoffs are there. That will surely make a difference.
Thanks, I'll try to post pictures when complete. Should be by the weekend or early next week. This has truly been an interesting process and has taken much longer than first thought. However, the outcome looks wonderful.
Scott
there is a bushing/sleeve that goes on each of the long studs that hold the upper and lower grill moldings in place that space the grille back from the opening. if you don't use these spacers, the front of the grill will rub the bumper. you can see the spacer in the area i've circled. i got mine at ACE Hardware and they are made of plastic or nylon and will not rust like the metal ones that were originally used. cost less than a $1 apiece...
Bill
