On starting the car either from hot or cold the engine does not fire until I release the key back to ignition and then just catches and runs fine. I can sit there and crank the engine for ages and it does not remotely sound as if it is going to fire.
It's as if there is no current getting to coil when engine is cranking.
Some one may have come across this starting issue before so I figure I will ask the knowledge base here before going and bothering the auto electrician.
It's obvious that the car has been "got at" by previous owners, particularly in the electrical area - odd connectors, a few wires going nowhere in engine bay etc.
I have just got my hands on this car after having to wait 2 1/2 months for it to be shipped halfway round the world and it's finally sitting in my garage.
I have to go down and pinch myself just to make sure it's real!!!
Neville
"It's as if there is no current getting to coil when engine is cranking."
I think you've found the reason for it not starting. All you have to do now is find the cause. I'd guess it's somewhere between the solenoid and the circuit back up to your coil when the ignition circuit is in the starter bypass mode. It's easy to check that wire with a test light. If it's dead at he solenoid, take it apart and clean the contacts. But, who knows, somebody could have eliminated that circuit.
As the guys above have indicated, you are missing electrical juice when the starting circuit is engaged. The starter solenoid has a separate contact for supplying the ignition coil when starting. This circuit bypasses the ballast resistor, so that full battery voltage is supplied to the ignition coil. The failure you are seeing indicates (as stated above) that the circuit is either malfunctioning, or not there to begin with.
Recommend getting a shop manual (which will have a schematic) for your Vette.
Good luck,
Plasticman
This forum is just great! Thanks guys for input- the links to wiring diagram helps I will admit. All the books I have - none have that diagram.
It's a bit late at night for my brain to start figuring out this so will check back tomorrow with progress.
Neville
You're looking for an 18-ga. pink wire from the "R" terminal on the solenoid (the outboard small stud); that wire runs through the branch of the engine harness that goes up and across the firewall, and it ends up at the coil (+) terminal, crimped to the same flag terminal that has the pink wire from the ballast resistor.
From: Putnam Valley, New York. Amateur Radio Operator K2NS
What you're saying is correct, but the coil should still be getting power through the ballast resistor even when the ignition switch is in the start position. Granted, it may only be getting 6-8 volts, but it runs at that voltage, and it should start with that voltage also. The solenoid bypass is for a full 12 volts to the coil for easier starting, but the original poster says that the engine just catches as he releases the key. I think he has 2 problems--a bad ignition switch which is not providing power to the ignition circuit when it is in the "start" position, and a missing solenoid bypass circuit. When I got my car 34 years ago, the wire to the solenoid "R" terminal wasn't there, but the engine did start while the key was in the start position.
Got it John.
Pink wire circuit was non-existent. Horn power feed was coming from run terminal, plus a few other odd connections
I have just been ferriting around in the loom between motor and firewall. I've unwound about what seems like 1000 metres of black tape!! There was an awful lot of wires in there that should not have been, some going nowhere, some twisted to others that looped back on themselves - in short MR Botchit had been there.
I decided it was an early morning job, so this morning took a deep breath and unravelled it all and removed all garbage wiring and reloomed the harness along firewall and reterminated connections.
I would say that something electrical has been added at sometime and wiring loom was hacked into. Suppose I have to kind of expect this sort of thing on a 40 year old car, but as an engineer I get a bit hacked off at some of the carnage that some people can inflict on these old cars.
Car now starts and runs fine - tick off one job.
