63 Steering Column NEEDS Twisting
So as not to hijack Olustee bus's thread
Y'all are hurtin' my feel good!
So you're saying this isn't correct either.
I thought it was a little odd the wires were exposed, about 20 degrees clockwise would fix the grove/channel issue. No pictures of the t/s cam and cable workings to confirm what you're saying.
Is the t/s arm in the neutral position parallel to the ground? Or is that off too?
NO! I don't consider you trashing my car!!! I'm open to suggestions as long as you help me fix it!!!!
Andy
AColbe01............since kenEDMUNDS started trashing your car, I will go next. In the picture you posted holding the key against the lower column, I can see that your steering mast jacket is rotated about 20 degrees to the left. The dimple in the retainer should rest in the groove on the mast jacket. It's not a safety issue, but it's going to mess up the geometry of your turn signal switch.
Andy
