Cooling trouble
I have not had time to get pictures just yet, but I will try to within the next day or so. I just got back from running the car and I'm very happy with this setup. the car now runs cooler setting in traffic than it does running down the highway at 65 mph.
Is there a web site where the cfm of the fan is rated without the shroud so I can compare it to others?
The Cooling problem has been solved
. To cover all the concerns with the timing I did go over the distributor one more time just to be sure. Everything there was right so I moved on to the airflow concern. I tried to install a SPAL dual 11 inch fan but ran into clearance issues. What I ended up with was a Flex-a-Lite single 16 inch with a full shroud part number 180. This fan fits like it was made for the car and moves 3300 CFM of air. My temp now will not go over 200 even sitting in traffic. If anyone else is thinking about going to an electric fan and would like pictures of the install let me know and I'll try to post some. Thanks to everyone who posted trying to help me out. See you all in CARLISLE
. To cover all the concerns with the timing I did go over the distributor one more time just to be sure. Everything there was right so I moved on to the airflow concern. I tried to install a SPAL dual 11 inch fan but ran into clearance issues. What I ended up with was a Flex-a-Lite single 16 inch with a full shroud part number 180. This fan fits like it was made for the car and moves 3300 CFM of air. My temp now will not go over 200 even sitting in traffic. If anyone else is thinking about going to an electric fan and would like pictures of the install let me know and I'll try to post some. Thanks to everyone who posted trying to help me out. See you all in CARLISLEWhen you have the opportunity to do the pictures, please send me a copy. I have just moved to Phoenix Az and will definitely need to do something about the issue.
Here are some pictures of the fan install. I didn't install the thermostat that came with the unit so that I could controll the cooling myself. What I did was wire it up using a relay and a toggle switch.
Specifications-
Part #: 180 Puller
Mounting Surface Required: 21 1/2" x 17 1/2" x 4 3/16"
Fan Assembly Diameter: 16”
Fan RPM @13.5VDC: 2450
Number of Blades/Fan Blade Angle: 8/variable
Airflow-Cu. Ft./Min. at 0º Static Pressure: 3300
Amp Draw: 18
Mounting System: Universal Brackets
Adj. Thermostat 160º-240º: Yes
Air Conditioning Relay: Yes
X-treme Replacement Parts (available for purchase separately)
Part # Description
30318-Motor
30331-Control Module
30159-Fan Blade
30078-Thermostat
Specifications-
Part #: 180 Puller
Amp Draw: 18
Part # Description
30318-Motor
30159-Fan Blade
30078-Thermostat
Thanks for the info. Looks great. Does the temp control plug into the engine or the radiator?
My Derale control has a small probe that sits between two radiator fins, so that the fan keeps the rad temp ready for the next time the engine tstat opens for cooler fluid.
Manual control is fine, but especially if you have an A-C exchanger in front of the rad, the engine temp gauge tells you nothing about the rad temp.
The controll unit that came with the fan does have the probe your talking about. It also has a setup to be wired in to your A/C relay. I just wanted to make sure it would do the job before I hooked all of that up.
POW-MIA, That's a nice looking install. One of the better jobs I have seen. I guess I didn't do a good job promoting what we have for this application so I guess better late than never?
You are right about the Dual Spals' not fitting. The duals are 23.5" wide and the BB core is 22.5" wide. What we do, is build an aluminum radiator to match the fans and then move the mounts back in an inch. This package fits without any mods and it's a beast. Obviously you must buy the radiator and fan combo for this to work and the shroud will not fit back on. The package is 2760 cfm and wiring/relays are included.
Here is the link to that product
http://www.dewitts.com/pages/product...asp?ProdID=266
If you simply want some cooling help when stop & go, then this is our kit for adding a puller fan. It provides 2360 cfm, mounts under the stock fan shroud, and uses the factory type radiator channels for a rugged mounting system. Wiring and temp switch is included.
http://www.dewitts.com/pages/product...asp?ProdID=321
Tom, I was well aware of your products and had spent a lot of time looking at your website. That is one awesome setup you have there. I would have gone with that setup but, I just had a new core put in the radiator last year. And was not looking to replace it just yet.
If I replace my aging Derale, I would just want the fan to mount in my BB shroud. What are the two vertical blackets that support the fan motor made from - plastic or metal? I made supports from aluminum to mate the Derale outer frame to my plastic BB shroud. If I have to throw away the blackmagic shroud, I will need to adapt the brackets.
The brackets are metal but, I think the real advantage of this setup is the shroud. If I was going to run something with the factory shroud it would be the unit that Tom is selling for that purpose.
I believe Tom only sells 2 types. One is the dual fan that requires me to reroute the factory A-C lines. The other mounts on the rad core or else on brackets that block the rad core. My 16 inch fan fills the factory shroud hole that the factory fan occupied, which pulls air from the entire rad core not just a round section. I hold 180F all the time in the city - even 100F days. It's the high speed highway running that is marginal. I don't like the 185 to 195F engine temps at 70-80mph with A-C running on a 100F day. The flex-a-lite fan is a 50% higher cfm than the Derale, so I believe it will do the trick - if it doesn't suck the core out of the rad tanks.
Thanks for the info on the vertical fan motor brackets being metal. The tech line guy at flex-a-lite said the brackets were nylon. I didn't think that would hold a heavy fan motor over potholes in the heat of the engine bay.
If the flex-a-lite shroud were wider and straddled the tanks the way the BB shroud does, I would go for it. My choice is to mod their shroud or just buy the fan and mod my current fan brackets. The brackets sound easier to me.
