Pedal Set & Interchange
Old Jul 8, 2007 | 05:20 PM
Vogie's Avatar
Vogie
Default Pedal Set & Interchange
I'm installing an automatic in my 66. I located a pedal setup for an automatic on the C3 Parts Forum. Anyone know if this will interchange into a C2?
Old Jul 8, 2007 | 05:35 PM
JohnZ's Avatar
JohnZ
No, it won't. All you need is the automatic brake pedal and the shaft that goes through it (the shaft replaces the one that's part of the clutch pedal) - there's no difference in the pedal support bracket.
Old Jul 8, 2007 | 05:42 PM
Vogie's Avatar
Vogie
Thanks John. I'm traveling and have none of my references available. I appreciate the information and I'll pass on the assembly.
To Pedal Set & Interchange
