Camshaft Source
Old Jul 10, 2007 | 01:20 PM
BrettG's Avatar
BrettG
Default Camshaft Source
Was recently advised that my cam has given up a lobe or two & will need replacement.
I've looked through my current array of catalogs including Pargaon, LICS, etc. to no avail.
Breifly looked on line @ Jegs & Summit but have been unsuccessful.
Any guidance appreciated.
Old Jul 10, 2007 | 01:25 PM
yesfam's Avatar
yesfam
What engine do you need a cam for? There is no information in your post or profile.
Plasticman's Avatar
Plasticman
I assume this is a cam for your 65 BB coupe, and you are looking for a stock, original type cam? You would need to confirm the above info, and supply the engine info as well (size, which I assume to be a 396, and HP rating)
Plasticman
Old Jul 10, 2007 | 01:38 PM
BrettG's Avatar
BrettG
You guys are quick today.......
I have 69 Corvette 427 block with the correct 208 heads for my 65 396 car. I have previously purchased the correct block for the car but will wait another year or 2 to install it. I'd rather purchase the correct cam for a 396 & install it in the current engine with hopes to use it in the 396 block at a later date.
To the best of my knowledge a 65 396 has mechanical lifters, can anyone confirm?
Old Jul 10, 2007 | 01:41 PM
Scott Marzahl's Avatar
Scott Marzahl
I am assuming that Crane Cams will have a stock replacement since they are/were the supplier for GMPP camshafts. You need to confirm your HP rating, the higher HP 396 used a solid cam while the low horse version used a hydraulic cam.
Old Jul 10, 2007 | 02:01 PM
MikeM's Avatar
MikeM
Be aware:
Even though the '65 and '69 solid lifter cams use the same grind, the rear cam journal has an oil groove in the '65 and doesn't in the '69.
A cam wears in to the lifters in a pattern dictated by the running position of the lifters on the lobe. If you change blocks with that cam and lifters, you'll likely have trouble with wiping a cam again. I wouldn't do it.
Federal-Mogul/Speed Pro makes a stock replacement solid lifter cam for your engine(s). I don't have the number.
Old Jul 10, 2007 | 05:42 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Comp cams also makes an improved version of it in their Nostalgia series. Makes a few more HP yet still acts stock.
Good point on the block oiling. You could use a grooved cam in the later block, but not the other way around. I also agree it's risky business switching flat tappet cams from block to block...but it can be done if you take a lot of care.
JIM
Old Jul 10, 2007 | 07:02 PM
JohnZ's Avatar
JohnZ
If you use a '65-'66 grooved cam in a '67-up block, you'll need to modify the rear cam bearing (solder the single oil hole closed and drill a new .062" hole 180* from it), or you'll have a major internal oil leak and reduced flow to the lifter galleries.
To Camshaft Source
