Pumping Gas
Old Jul 18, 2007 | 10:44 AM
Eddie Lewis's Avatar
Eddie Lewis
Default Pumping Gas
This may be a dumb question, but the gas stations in the Dallas area have gone to the low emission gas pump. It won't work unless there is a complete seal at the filler opening. Therefore, it won't work on my 67 coupe. How have you overcome this problem? Thanks.
Old Jul 18, 2007 | 10:49 AM
Red63SW's Avatar
Red63SW
I have the same problem with my 40 Ford. If they are the same pumps as the ones we have had in California for years, try holding back on the spring loaded seal with one hand so it doesn't seal. It works on our pumps.
Old Jul 18, 2007 | 10:57 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I had a similar problem with my 77. I bought a permanent gas cap that has a filler hole in it - since then, no problems.
Old Jul 18, 2007 | 12:02 PM
achapman's Avatar
achapman
When I go to shows I use the correct gas cap..... When I go to fill up I use a modified gas cap with a filler hole in it. Got it from Jegs about 4 years ago, think I paid around $20 for it....
Old Jul 18, 2007 | 12:10 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I found mine at Advance Auto Parts when I was tired of trying to hold the sleeve back so that the pump would run. There's something in my tank that won't allow a nozzle to go in very far. I can't recommend it highly enough.
Old Jul 18, 2007 | 01:59 PM
JAF1's Avatar
JAF1
Do you have a part number or remember the name of the manufacture? I tried looking around on Jegs and Summit but didn't see anything.
THANKS!
Old Jul 18, 2007 | 03:20 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
When I run into a gas station with those filler nozzles I jam the collabsible rubber neck against the side of the gas tank filler neck and force it back. That works. I also wrap a towel around the filler area so I don't get gas spray on the paint. They do tend to shut off on you and you can get a splash when you start it back up.
Old Jul 18, 2007 | 05:35 PM
magicv8's Avatar
magicv8
I got a new gas cap 9/10 years ago and drilled a hole in my old one. I keep it in a plastic bag.
Old Jul 18, 2007 | 09:28 PM
stall's Avatar
stall
Does anyone have Al Gore's phone number, he may have the answer?
Old Jul 18, 2007 | 10:07 PM
Glenn's 67 BB Vert's Avatar
Glenn's 67 BB Vert
He invented those the same year he invented the internet He most likely invented global warming too so that he would have a platform
Old Jul 18, 2007 | 10:38 PM
GCD1962's Avatar
GCD1962
He's unavailable. He's home eating Chilean Sea Bass. A fish on the "bug lovers" watch list. Heard today he had it on the menu at a recent event he was giving.
Old Jul 18, 2007 | 10:53 PM
Blkblt's Avatar
Blkblt
He's also managing the zinc mine he and his family own in his home state that has a record of both making money and discharging waters over permit discharge effluent limitations. How cool is that.....
Old Jul 18, 2007 | 11:10 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
THANKS!
http://www.kleenwheels.com/about_permacap.htm
Old Jul 18, 2007 | 11:33 PM
Cruzmeisters's Avatar
Cruzmeisters
Bought one at Advance Auto for my wife's Buick LaCrosse so that she wouldn't have to remove the standard cap & hang it from the gas door when filling up; cost $9.95. It was different than the one on her (previous) '96 Buick Regal, but the Regal cap fits my '96 IMP/SS
When she went to New Jersey, the pump jockey INSISTED - by law, I guess - on pumping gas...and BROKE it! She didn't know it was broken until she went to fill up upon returning to Pennsylvania With my (BELIEVE ME ) LIMITED mechanical skills, I was able to get it back together...and it works!
Cruz
Old Jul 18, 2007 | 11:52 PM
bweaver999's Avatar
bweaver999
I would be very interested in this as well. The PermaCap is not for C2's, their application guide states it is only for newer cars with screw type caps.
Cruz:
Yes, it is NJ law, drivers are too stupid to pump our own gas, only attendants. Actually not a bad law when raining like crazy or cold. When you pull up in a C2, most attendants seem more than eager to pass me the nozzle.
Old Jul 18, 2007 | 11:54 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That's the one I had to use. I think I've seen other manufacturers, but I don't remember the names.
Old Jul 19, 2007 | 01:03 AM
bweaver999's Avatar
bweaver999
Ecklers has the PermaCap:
http://www.ecklers.com/product.asp?p...1&dept_id=1280
Fits 75-95 only.
C2's are way different:
http://www.ecklers.com/product.asp?p...7&dept_id=1280
Actually 63-69. The cap is 1/4 turn and grips from the outer edge. Probably too limited an application.
Old Jul 19, 2007 | 01:17 AM
Herbs66's Avatar
Herbs66
If its the kind with the compressible rubber boot you can do what a couple of the others have said and just use your other hand to compress it or use the side of the gas tank filler neck to compress it to make the switch in the nozzle think its sealed.
Old Jul 19, 2007 | 01:47 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Fits 75-95 only.
1/4 turn to latch, outside edge grip? I don't know if the diameter is the same, but that sounds like the gas cap used on GM trucks in at least the '47-'72 period, possibly even further each way. Maybe something could found under that application. There are some screwball parts interchanges in the Corvette line.
To Pumping Gas
