BTW - got the PV with the 1963 - was hot and humid day in Bahstun, but had NO percolation problem with the CAM 2 in the gas tank - had basically run the car almost to empty and put in 2 1/2 gallons - set the idle mixture settings like you advised
You should be very proud of your car, Rick. That's a tough test to pass.
