Need some help please.....
Old Aug 14, 2007 | 07:07 PM
GA67Terp's Avatar
GA67Terp
Default Need some help please.....
Drove the '62 over 100 miles last Sunday (a week ago) and was running great. Came home, put her in the garage and assumed all was good. Tried to start it this past Sunday and seems something went bad wrong during the week. Car started briefly (running very rough) and then just quit. While trying several times to restart, I obviously flooded it and decided to let it sit for a couple of days. Yesterday, pulled the plugs(those from cylinders 1, 2 and 4 were real wet and fouled pretty badly). Decided to replace the plugs which I did today. Also checked the points, rotor, distributor cap and pulled the fuel filter to be sure there wasn't a blocked line. Some small particles but nothing major. Fuel supply doesn't appear to be the problem.
Anyone have any idea what I might be up against here???
Any and all help appreciated.
Old Aug 14, 2007 | 07:13 PM
Trophy Blue's Avatar
Trophy Blue
The float(s) could be stuck down so the carburetor floods. I would suspect that it is a carburetor issue. Take the sight plug out to see if gasoline pours out of the hole.
Old Aug 14, 2007 | 07:18 PM
62Jeff's Avatar
62Jeff
I agree with the stuck float assessment, but I don't think any 62 carb had a sight plug. My 327/340 has a carter 4269S AFB - no sight plug. I think the lower horse engines had WCFBs
Old Aug 14, 2007 | 07:23 PM
GA67Terp's Avatar
GA67Terp
Thanks for the quick replies....my '62 is 300HP with an AFB3269 and I agree there is no sight plug. Guess I'll have to pull it apart to see if the floats are hanging up.
Old Aug 14, 2007 | 07:30 PM
Trophy Blue
Sorry, I have "Holley's On The Brain Disease". It's a mid year disorder.
Old Aug 14, 2007 | 07:31 PM
62Jeff's Avatar
62Jeff
If you can carefully look into the top of the carb while trying to crank the car, I'd think you'd be able to see fuel pouring into the intake - if it doesn't backfire through the carb and take off your eyebrows.
When the float in my 62 got stuck, fuel would drip off the throttle shaft onto the passenger side of the intake.
Old Aug 14, 2007 | 07:34 PM
LB66383's Avatar
LB66383
It could be dirt in the needle & seat. I've had success with cutting off the fuel supply to the carb (disconnect and plug the line if it's metal, pinch it off if it's hose), then starting and running the engine until it stalls. This mostly empties the float bowl and lets the float drop. Then hook up the fuel line and crank the engine. The fuel surge from the pump might just blow the dirt out of the needle/seat and it'll be fine.
Old Aug 15, 2007 | 12:18 AM
Cruzmeisters's Avatar
Cruzmeisters
Just throwin' this out there, since I'm not mechanically inclined...but it happened to me: drove to a Cruise in the '62, started backing into a parking space. It stalled & wouldn't start; gear-head buds came over & started checking & wound up removing the metal band holding the ballast resistor to the firewall. It was cracked completely through! They by-passed it, allowing me to get home & to my mechanic the next a.m.
Cruz
Old Aug 15, 2007 | 01:37 AM
Driver 61's Avatar
Driver 61
I had a stuck float on my 61. I slapped the side of carb with a mallet. It has not misbehave since.
Old Aug 16, 2007 | 05:40 PM
GA67Terp's Avatar
GA67Terp
Follow-up to my original post.....
Tried solidly tapping the carb with a rubber mallet to see if floats were hung up causing the problem. Tried to start the car with no change in the symptoms.
Pulled the carb and disassembled to see if floats were hanging up. No obstruction..they are operating freely. Next checked to see if there was any debris in the idle mixture screw passages. Did find a little obstruction in both. Blew them out and reassembled the carb and reattached to the manifold.
No luck...same symptoms as before...motor starts briefly and then dies...
Not sure where to turn next other than have it towed to the shop and have someone more knowledgeable than me to figure it out.
Thanks to all who responded earlier.....
Old Aug 16, 2007 | 05:50 PM
66L72's Avatar
66L72
just curious
it is not a situation where it starts then dies when you release the ignition key to the run position is it?
Old Aug 16, 2007 | 05:51 PM
USALT1's Avatar
USALT1
"ALWAYS" wear glasses or safety glasses when looking at a Carburetor on a car.
Old Aug 16, 2007 | 05:52 PM
Double-E's Avatar
Double-E
Default Need Some Help
If it cranks and doesn't start,did you check ballast resistor?jumper across it to see if it starts;don't leave the jumper on long
Old Aug 16, 2007 | 06:02 PM
3869942's Avatar
3869942
Unfortunately not familier with early Carters (Holley-on-the-brain from a previous post might explain this), but wondered if your carb has anything like a vacuum qualifier diaphram or choke unloader? This serves to pull-open the choke plate a little bit right after the engine fires so it doesn't die/flood. If you have a failure like this, it would offer similar failure symptoms.
Old Aug 16, 2007 | 06:20 PM
Bill Pilon's Avatar
Bill Pilon
My ballast resister went out with the same symptoms, drove it, ran fine, sometime later went to start it, it would start ok but it quit when the key would return to on.--Bill
Old Aug 16, 2007 | 08:16 PM
GA67Terp's Avatar
GA67Terp
Releasing the key to the "ON" position does not seem to be the problem. Several times the motor has run roughly (loping) for up to 30-45 seconds after starting but then seems to load up and quit. I'm not familiar with the vacuum qualifier diaphram or choke unloader so I can't answer that question. Will check the ballast resistor to see if that may be the problem.
Again, thanks for all the input. If I find the problem, I will repost for future reference.
Old Aug 17, 2007 | 09:07 AM
3869942's Avatar
3869942
The unloader of VQD serves to open the choke after starting. To see if the choke opens a little bit after starting, observe the choke plate static, engine off, choke engaged (cold). Stand back and watch as someone cranks the engine...when it fires, does the choke plate open "some" (let's say 1/6-1/4 of it's full travel)? If not, the engine will generally load up and die. If it does open somewhat upon engine firing, this is probably not the problem.
Good luck.
Old Aug 18, 2007 | 09:22 PM
GA67Terp's Avatar
GA67Terp
Turns out replacing the points and coil solved the problem. The Vette fired right up so I can't say for sure which of the two was bad but suspect the points since they were pretty badly pitted and worn. Thanks to all who responded with suggestions.
Old Aug 18, 2007 | 09:29 PM
piper's Avatar
piper
To Need some help please.....
