66 head light help
There is switch located on the headlight rotating shaft that stops the motor dirve when the light is fully rotated. I am not sure how this might cause the motor not to drive, but it is something that you might want to check.
The only other suggestion I might have is to insure you are connecting power to the right connection when you hot wire it. Remember that motor dirves both ways and if you connect to the wrong pin then you will be trying to drive it down and this switch would prevent the motor from turning in that direction.
If they are:
Check for voltage on the red wire of the headlight motor switch.
If there is no power check for power on both sides of the circuit breaker. If there is only power on one side, the circuit breaker is faulty.
If there is power at the red wire of the headlight motor switch, operate the switch "up" and check for power on the blk/yellow wire, then operate switch "down" and check for power on the green wire. If there is no power at the blk/yellow wire and the green wire the switch is faulty.
If there is power at the blk/yellow wire and the green wire,
remove one of headlight motor connectors and check the voltage at the connector while operating the headlight switch up and down.
If there is no voltage at the headlight motor connector, disconnect the outboard bulkhead connector, check and clean the contacts of the blk/yellow wire and the green wire. Reconnect the bulkhead connector.
and check for power at the headlight motor connector. If you have power, reconnect the headlight motor connector.
Operate the headlight motor switch up and down. If headlight motors don't work, check ground on headlight motors.
My money is on corroded contacts in the bulkhead connector, or a faulty circuit breaker.
Dave
Dave,Thanks again
Craig
