64 Engine Stalling.
Old Aug 17, 2007 | 03:31 PM
buffalo318's Avatar
buffalo318
Default 64 Engine Stalling.
My 64 327,300HP Powerglide recently started stalling when using the power brakes. Sometimes, but not always. I'm thinking its a vacuum issue. Any other ideas? If that's the problem, what's the likely fix? Thanks.
Old Aug 17, 2007 | 05:51 PM
JoesC5's Avatar
JoesC5
With the engine running, press on the brakes and see if you can hear a air leak(sounds like rushing air) coming from the brake rod under the dash. If so, does it stop when you release the brakes? If you do hear the leak, most likely the diaphragm has gone south.
