Speedo needle bouncing
Old Aug 19, 2007 | 10:58 PM
54greg's Avatar
54greg
Default Speedo needle bouncing
Just had my gauge cluster rebuilt. Now my speedometer needle is fine one moment and the next bounces erradically. Any ideas?
Old Aug 19, 2007 | 11:05 PM
Cj_'s Avatar
Cj_
I have the same thing happen, but only when it is very cold. Usually indicates binding in the cable.
Cj
Old Aug 26, 2007 | 07:40 PM
Dave Tracy's Avatar
Dave Tracy
Make sure the cable is lubed.
Old Aug 26, 2007 | 08:16 PM
gldnkngt's Avatar
gldnkngt
Assuming that it was a good re-build, more often than not a bouncing needle means an old or worn or under lubed cable. Just don't over-lube it, because that can gum up the works as well.
Old Sep 19, 2007 | 07:51 PM
heulian's Avatar
heulian
1st Gear
Mine did this, and it was actually due to a jammed odometer. The speedo gear was trying to roll the odometer forward, it wasn't rolling, and eventually the speedo would 'snap' into the next gear-- making a clicking sound and making the needle bounce.
To Speedo needle bouncing
