Tail light problem
Old Sep 5, 2007 | 11:53 AM
ErminewhiteC2's Avatar
ErminewhiteC2
Default Tail light problem
Last night i was driving with the lights on. When I came to a stoplight, someone behind me said I had a tail light out. When I got home i checked it out. With the lights off the brake lights work fine, but with them on when I apply the brakes the passenger side goes out completely. Can soneone tell me what I should look for? Thanks in advance.
Old Sep 5, 2007 | 12:38 PM
tentuna's Avatar
tentuna
Sounds like the turn signal switch
Old Sep 5, 2007 | 12:42 PM
piper's Avatar
piper
Try pulling your light switch **** out and in a few things. Also turn it a few times
Old Sep 5, 2007 | 12:45 PM
ErminewhiteC2
Now that you mention it, my turn signals have been acting up lately
Old Sep 5, 2007 | 12:46 PM
stingrayl76's Avatar
stingrayl76
Sounds like a bad ground on the passenger side taillights. Make sure The sockets and bulb bases are clean. Check the ground wire that is connected to the taillight housing mounting bolts. Removing the rear valance panel will make checking those wires a much easier job.
Old Sep 5, 2007 | 09:21 PM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Definitely sounds like a bad ground. I had the same on the wife's 66.
Old Sep 5, 2007 | 09:57 PM
chrismoore701's Avatar
chrismoore701
Just had the same problem on my '63. I took the sockets off the car and cleaned them with a light grit sandpaper, and there is a tab in the socket, take a small screw driver and pull the tab out just a little and that should fix your problem, if anything, a good place to start.
Chris
Old Sep 7, 2007 | 04:16 PM
piper's Avatar
piper
Did you find the problem?
Old Sep 7, 2007 | 04:54 PM
ErminewhiteC2
I haven't had time to look at it yet. This weekend doesn't look any better. I just got new back-up lights, but haven't found reasonably priced red ones. Anybody have any aftermarket ones the would like to part with? I am going to wait until I have all 4, so I can put all of them in at once.
To Tail light problem
