Altenator conversion help?
Old Sep 17, 2007 | 01:19 PM
jmhart9's Avatar
jmhart9
Navigator
Default Altenator conversion help?
Ive got a 66 small block car and I want to upgrade the charging system to an internal voltage regulator or possibly a 1 wire set-up.
I'm sure one of you guys have done this before and some step-by-step guidance would be a huge help, but just pointing me in the right direction for the info would be greatly appreciated as well.
Thanks,
Jeff Hart
jmhart9@bellsout.net
Old Sep 17, 2007 | 01:31 PM
John S 1961's Avatar
John S 1961
Default Meet my Friends WWW.Madelectrical.com
Here is the source of good data, Its really pretty easy. Begin you studies here. Dont use a one wire alternator. Do add relays for your headlights.
Old Sep 17, 2007 | 02:56 PM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
Click on Misc item/info and find information on alt conversion
Start here ====>>> Click Here
George
Old Sep 17, 2007 | 02:58 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
my .02; DO NOT use a 1 wire...
Bill
i guess i should explain why you shouldn't use a 1-wire.
the 1-wire alternator generally does not provide any charge until the rpms get high enough for it to generate enough internal power to begin output; this usually occurs above 1500 rpms.
short version: it doesn't charge at idle... it is best suited to applications where the rpms are consistently above 1500.
Old Sep 17, 2007 | 03:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Bill
it's a Corvette, not a tractor or boat.
Old Sep 18, 2007 | 12:27 AM
buns's Avatar
buns
Here is all you need, an Alternator Conversion Harness. $17.00 from Corvette Central, made by Lectric Limited.
Also available from MAD. That's where I stole these instructions.
Old Sep 18, 2007 | 01:48 AM
JohnFromVentura's Avatar
JohnFromVentura
Has anyone used the waterpump that has an alternator integrated into it (it's pretty slick)? Know how much current it produces and how much it costs? I think it takes an external regulator?
Old Sep 18, 2007 | 08:15 AM
kenmo's Avatar
kenmo
Wow...never heard of that one... Please post info...
Old Sep 18, 2007 | 02:27 PM
kenmo's Avatar
kenmo
I think the GM 10Si alternator (3 wire) would be a better fit then the one wire...
Here's a link to a comparison of the two...
http://www.madelectrical.com/electri...hreewire.shtml
Old Sep 18, 2007 | 02:53 PM
darguy's Avatar
darguy
I read this over before having my original '64 alternator rebuilt by a local shop. Replaced the regulator at the same time and now have ~14 V and 70 A max output.
Old Sep 18, 2007 | 02:58 PM
JohnFromVentura
I have seen this only once ... it is quite impressive without an alternator or belt. I think its a race item available from Jegs etc or the more hard core race shops?
Old Sep 18, 2007 | 06:25 PM
hpexpatriot's Avatar
hpexpatriot
I don't understand this one wire thing.
What is the reason that people even want 1 wire alternators? It cannot be just the the fact that there is only 1 wire......... can it???? Are people realy thinking that 1 wire is more neat and clean LOOKING than two or three wires and not even considering the operational limitations of 1 wire alternators???? A buddy ofmine is building a street rod and he has one. I expect that he is going to see that it is not as "cool" as he thinks but since he already has the thing I am not saying anything.
Old Sep 18, 2007 | 06:32 PM
toddalin's Avatar
toddalin
Bill
Sorry, but you're wrong. I use a 1-wire alternator on my '64 with absolutly no problems.
Yes, you have to goose the engine up to about 1,200-1,300 RPMs, but just once when you start the car..., and who doesn't do that anyway?
After that, it stays energized and will charge at idle like the stock alternator until the ignition is shut off.
Mine is rated at 100 amps and certainly outperforms the stock 42 amp (or whatever it was) unit.
Just mount the thing, attach the red wire that goes to the battery, and you're done. I also attached the old ground wire to the case, because it was there and couldn't hurt. I just cut the two wires on the plug and tucked them back into the loom. Can't get much easier than that.
Old Sep 18, 2007 | 06:37 PM
toddalin's Avatar
toddalin
Goes beyond just the aesthetics of the one wire. You also get to throw away the harness and the external regulator that clutters up the radiator support.
And what operational limitations??? I have to goose the engine once to about 1,200 -1,300 RPM when I start the car (and who doesn't do that???) and after that it stays energized and functions like the old unit (except it puts out a lot more current).
Old Sep 18, 2007 | 06:44 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
different strokes for different folks...
Bill
Old Sep 18, 2007 | 09:53 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The sense wire is there for a reason. Without it, you're not getting full power down the line.
Old Sep 18, 2007 | 10:41 PM
toddalin's Avatar
toddalin
OK..., so I'm only getting 99 of my 100 amp rating??? It's still far more than the original 38 or 42 amps.
Anyway, don't you think that they would have found a way around the "sense" wire?
Always seemed to me on an alternator that you have a battery connection, a ground, a field, and a secondary "boost" wire for the lights (your noted "sense" wire). Seems to me that the only connection that could be lost is the "boost" for the lights, and if it is putting out near its 100 amp rating, this would need to be enabled internally with a jumper.
To Altenator conversion help?
Old Sep 19, 2007 | 12:42 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'm not talking about an amperage drop, I'm talking about a voltage drop. The one-wire design still uses a sense circuit, but it's contained within the alternator housing. They were designed for boats and tractors, where the entire electrical system is contained within a small area.
Here's the facts on the way the different systems work. Everyone is welcome to educate themselves: http://www.madelectrical.com/electri...hreewire.shtml
Old Sep 19, 2007 | 12:36 PM
Russ T Gate's Avatar
Russ T Gate
I have a 140 amp 1 wire alternator that I've run for 5 years without problems, however if I ever break down in the middle of the boonies I'm screwed. Not many auto parts stores carry 1 wire replacements.
Russ
Old Sep 19, 2007 | 01:43 PM
1COOL60's Avatar
1COOL60
From: Emporia, pay no attention to that man behind the curtain, KS
I put a 1-wire in my '60 somewhere around 12 years ago. I never had any problems, until the bearings started making noise a couple of months ago. So I took it to O'Reilly's and traded it in for another 1-wire alternator. They carry them in stock, or at least the O'Reilly's in Emporia KS does. It was rebuilt by Dixie Electric, who is a major rebuilder. Detroit Diesel Remanfacturing buys starters and alternators from Dixie Electric.
And in my opinion, the MAD Electric article that is linked to above is not much more than a glorified sales pitch.
Have a nice day.
