Antenna Question
Old Sep 18, 2007 | 01:51 PM
65 vette dude's Avatar
65 vette dude
Default Antenna Question
Can somebody tell me the finish on the original antenna mast? I'm replacing my aftermarket with a reproduction and the bezel and nut on the repro are chrome, but the mast is stainless with a satin finish. Is this correct?......Thanks,Gary
Old Sep 18, 2007 | 03:42 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
that sounds correct to me
Old Sep 18, 2007 | 08:25 PM
gthompson49's Avatar
gthompson49
Default 65 66 Power Antenna
The masts were chrome plated.
Old Sep 20, 2007 | 08:09 PM
66jack's Avatar
66jack
It sounds right to me..but my repo has the wrong tip on it..I have the original mast but no motor....how do i swap the tips....
jack
Old Sep 20, 2007 | 08:59 PM
gthompson49
Clamp the last mast section in some brass faced jaws. Place a layer of tape over the tip. Get a deep 1/4 inch socket and CAREFULLY twist and break the tip loose. Rotate back and forth while slightly cocking the socket and pulling on it. (sounds weird but it's pretty easy) The tip will slip off.
You can try to press it on your original with some Loc-tite if your brave. I tap the tip and the mast with a #4-40 thread and thread it on. Never had one come loose.
Of course the recommended practice is to use a rebuilt original from a respected restorer.
Old Oct 17, 2007 | 04:17 PM
C.W.C.'s Avatar
C.W.C.
Default Corvette Antenna
Hello All,
I Just Purchased A Restored Antenna From Greg Thompson (a Fellow Forum Member) And The Quality Was Terrific And He Is Truly A Great Person. Very Professional!
Chuck Commerford
To Antenna Question
