Engine Judging
A couple of questions for you--do you believe this engine to be your original engine? Based on your screen name, I am assuming the engine is going into a 65 FI car. Is the engine suffix correct for your car's configuration (i.e. is it an FI suffix)? If that is the case, I would procede with some caution. If you can get a high resolution picture of the pad and stampings, you would be doing yourself a huge favor to have Al Grenning authenticate the pad. I do not know what he will charge for this service but it would be cheap insurance.
http://ccas4vettes.com/
You can also post it here but to be honest, this group is not nearly as good as Al, nor do they have the extensive library of pads with grind outs, stamp overs, etc.
If you do not think this is the original engine for your car but you are simply looking for something that would work for judging, I do not think I would pay 2x what a similar engine would cost. NCRS will allow the correct casting number to have been cast within 6 months of your car's build. If you meet those criteria you will get most of the engine case judging points. If the engine is undecked, but is out of a passenger car you will also get credit for the deck surface and only loose 50 pts for the VIN and engine configuration stamps being wrong. Shoulld not be too hard to find a 65 passenger car 870 block cast within 6 months of your build date so this would be the more economical route.
Good luck
