engine compartment question
Old Oct 13, 2007 | 03:30 AM
65 vette dude's Avatar
65 vette dude
Default engine compartment question
Anybody know the correct finish on a 65 brake booster and clutch z bar? Also I have a double (inner and outer) carb return spring on my L79,is that original?.......Thanks,Gary
Old Oct 13, 2007 | 06:25 AM
ratmotortom's Avatar
ratmotortom
Platinum Supporting Dealership
Booster is cadmium dichromate plated. Clutch cross shaft is also cad plated As per 65 Judging Manual.
( Corrected my original comment that was wrong about Z bar finish ! )
Old Oct 13, 2007 | 09:14 AM
geo65's Avatar
geo65
the clutch Z bar should be cad plated....
Old Oct 13, 2007 | 09:23 AM
62Jeff's Avatar
62Jeff
2 carb springs is not original, however it's much safer and an easy thing to change on the judging field. I run 2 springs on all of my older cars, and in the case of my 62 (the only old one I showed for accuracy) I simply removed the incorrect inner spring as part of my prep work on the show field
Old Oct 13, 2007 | 09:40 AM
ratmotortom
This is correct. I mis read the manual and quoted the finish for the mounting bracket instead of the cross shaft itself.
I stand corrected.
To engine compartment question
