SB code V1129F
Old Oct 14, 2007 | 08:36 PM
67L36Driver's Avatar
67L36Driver
Default SB code V1129F
What is/was it? 327, 307 or 350? '69(?) or later block as there is no vent boss at the rear. Square head 1/8" pipe plug in the oil gallery above the timing chain cover.
The short block that was in 'Old Blue' when I got him has this engine code. It now resides in my '40 Ford.
Also attached to the outside front of the valley just above the timing chain cover is a rebuilder's tag.
Product of 4 State Motor Parts, Tulsa Ok.
cyl......C
rod......A
main....A
If A = .010" then C = .030"............. I suppose.
Old Oct 14, 2007 | 08:52 PM
knight37128's Avatar
knight37128
What is the date code on the block? Also get the casting number.
I have a 55 or a 57; both are two barrel motors.
Old Oct 14, 2007 | 10:03 PM
67L36Driver
Default Casting # 3932386
L I B. Mortec shows the block as a '69 350, but it could have a late model cast 327 crank in it. Answered my own question I think.
Can't get my eyes to focus on the date code, battery box is in the way.
This short block had a pair of 225 hp 265" heads on it when I bought 'Old Blue'. With flat top pistons the C. R. was way up there. Wouldn't run on regular so I changed them to some early '70's smoggers. Sold the 225 hp heads to a shoe box owner in my neighborhood.
Old Oct 16, 2007 | 09:04 AM
67L36Driver
Default V1129f
So what motor plant starts with a 'V'. Not Flint or Tonawanda but where?
What suffix whould have had an 'F' around '69?
Old Oct 16, 2007 | 09:16 AM
Joel 67's Avatar
Joel 67
V is actually for flint. I am not sure when they switched from F to V. Mid 60s IIRC.
Old Oct 16, 2007 | 09:31 AM
ctjackster's Avatar
ctjackster
V = Flint beginning in 1967 M.Y.
Old Oct 16, 2007 | 11:56 AM
JohnZ's Avatar
JohnZ
None. The single-character "F" prefix was last used in 1961, on passenger car 283's. All 69's used a two-character suffix.
Old Oct 16, 2007 | 12:52 PM
67L36Driver
John:
How about an FB suffix?
The B is stamped separate and I disregarded it thinking it was from the rebuilder.
Old Oct 16, 2007 | 02:11 PM
JohnZ's Avatar
JohnZ
John:
"FB" in '69 was a 327/235hp 2-barrel Powerglide Impala/Caprice.
To SB code V1129F
