62 info needed
Old Oct 17, 2007 | 07:01 PM
Red63SW's Avatar
Red63SW
Default 62 info needed
I am going to look at a 62 soon and need some help. I've searched CF and found that the VIN tag is on the steering column underneath the hood. I also read that there are no trim tags until the 63 model year. Other than engine pad stamps, are there any other identifying codes or numbers on a 62? Is there a way to determine the original paint/interior color and optional equipment?
Old Oct 17, 2007 | 07:11 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
No.
Not directly, anyway,
you can look for clues, like paint color on the dash with the pad removed or on the floor under teh carpet, tach redline, etc, but those are not guaranteers of anything.
Doug
Red63SW's Avatar
Red63SW
Can anybody elaborate on the various redlines on tachs?
Old Oct 17, 2007 | 07:16 PM
Qblue92's Avatar
Qblue92
St. Jude Donor '08
You might be able to discover the original paint color with lots of sandpaper! or... if you remove the vertical board in the front of the trunk, there might be a good hint. They wrote the color the car was to be painted on that panel in some kind of green? waxy crayon. I've heard you can get a clue there.
All the vin will tell you is the build date.
Old Oct 17, 2007 | 07:43 PM
Ironcross's Avatar
Ironcross
lower performance engines {hydraulic cam equipped } has a 5500 red line. the 340 and 360 HP engines use the 6500 redline.
1955 copper's Avatar
1955 copper
2015 C1 of Year
I wrote about it 20 years ago
To 62 info needed
