Headlight warning lamp flashes
Old Oct 17, 2007 | 11:51 PM
ah53's Avatar
ah53
Default Headlight warning lamp flashes
When I first rotate the headlamps all is fine, but if I hit a bump the warning lamp will begin to flash till I open and close the buckets again. I have looked in AIM and the shop manual and neither is very clear. Can someone shed some light on how to correct the problem. Please forgive the last sentence as there was no pun intended.
Joe
Old Oct 18, 2007 | 01:27 AM
62Jeff's Avatar
62Jeff
The headlamp warning light flashes when:
1) The headlights are on, and
2) At least one of the headlight buckets is not fully opened.
I suspect there is some play in your headlights due to wear on the gears, and when you hit a bump one of the headlight buckets ever so slightly closes, thus triggering the switch which tells the headlight warning lamp to activate.
Old Oct 18, 2007 | 10:45 AM
RoadVettes's Avatar
RoadVettes
This occasionally happens to me, and when it does I just hit the headlight "up" switch a little and the light stops flashing.
Charlie
Old Oct 18, 2007 | 11:35 AM
67L36Driver's Avatar
67L36Driver
Screws holding the tattle tale switch loose on one side?
Old Oct 18, 2007 | 07:15 PM
ah53's Avatar
ah53
Thanks for the help. Hopefully it's a screw loose --- on the switch not me.
To Headlight warning lamp flashes
