Overheating Problem
Old Mar 2, 2008 | 09:27 AM
kabong's Avatar
kabong
I have had my 60, for almost 35 years now. I'm on my 6th engine,ALL of which had the same problems you are now having. I have a shelf full of clutch/flex fans, drilled/no thermostats,rodded original radiators to Desert Coolers, and every other quick fixes there have been over the years. I then purchased an aluminium radiator from Dewitts and, problem solved. The 283 I have in there now is bored out .060 and still runs cool. I would go with this first. Again, just my opinion.
Old Mar 2, 2008 | 09:40 AM
ctjackster's Avatar
ctjackster
I'm still curious to hear if ddsJoseph solved his run-hot problem by trying whatever fixes he decided to pursue?
Old Mar 2, 2008 | 11:30 AM
64tux's Avatar
64tux
Originally Posted by Brumbach
I'm sorry, I didn't mean to reopen the thread..just get an answer to one of the points made my a member. I was seeking the reason a car would expell coolant thru the overflow when you shut down. My 68 is doing it at the present.
mine will do that when i've over filled the radiator tank. maybe someone else has a different idea???
Old Mar 2, 2008 | 11:43 AM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Or a bad cap.
Old Mar 2, 2008 | 11:58 AM
6T5RUSH's Avatar
6T5RUSH
Cruise-In III Veteran
Kinda' refreshing to read of run hot issues (I'm sittin' here in my great room on a typical Michigan day)
Weather for Clinton, MI
30°F
Cloudy
Wind: SE at 14 mph
Humidity: 80%Sun
40°F | 34°FMon
43°F | 26°FTue
31°F | 23°FWed
33°F | 21°F
This topic does give me hope that there is a spring around the corner.
All good advice to get to the heart of your overheating. Keep the word KISS in front of you in your approach (although that aluminum radiator will be on your list).
Good luck!
Regards,
Jim
Old Mar 2, 2008 | 01:25 PM
bweaver999's Avatar
bweaver999
Originally Posted by Sky65
Or a bad cap.
The reason it pukes when you shut it down is while it's running the fan is pulling air through the radiator and the pump is moving the coolant. When you stop the engine, it continues to warm a bit more with no cooling ability. The pressure increases due to additional heat build and it pukes.
A new correct cap should cure that.
Old Mar 2, 2008 | 02:45 PM
ffas23's Avatar
ffas23
Check your timing and try replacing the Radiator Cap. I did both and don't have the problem anymore in my car.
Old Mar 2, 2008 | 02:54 PM
MikeM's Avatar
MikeM
Or maybe your engine is really hot. I suspect it's just overfull.
I run my '65 2* BTDC, right where the books says to. I have a very old radiator cap on it. May be original and I have a copper radiator in it. No problems.
