Slow Headlight?
Steve Berson
Gears, shims, limit switches, thrust washers, and most other major parts are available from Corvette Central.
Originally Posted by Tom E. View Post
One headlight on the '65 is a little lazy and slow to go up & down and also kind of whines and squeals... With What & Where to lube? Or bigger problem?
This is a great DIY project. Get an AIM and pull the gearbox & motor assemblies. Dissasemble the gearbox, clean out all the old lube, check the main gears, clean the motor assemblies with electrical cleaner, reassemble, test, and re-install. Hardest part is getting the assemblies on and off the car. Just finished a set of '63's, here are some photos that may help you..... http://ckautollc.phanfare.com/album/...ageID=27593501
Solidaxle,
Great slideshow! Couple questions. Any pointers or tricks needed to remove the assemblies? Did you media blast the cases? Anything you need to watch out for during disassembly like springs or pins flying out? Also any special oils or lubes? Thanks.
1. Wire connections. Clean all of them, get out your wire diagram in chassis service manual. Start at bulkhead connector, don't forget your ground wires.
2. Lube or lack thereof. Drop of oil on the motor shaft ends and new lube in gearbox.
3. Chewed up output gear in gearbox. $50 buys a pair from most of the vendors. Don't bother with the 'turn gear 180 degrees' trick, fix it once and never worry with it again.
When you get the motor out, run it on the workbench with a battery or battery charger. Run it both directions. Give it a chance to 'self clean' the brushs and commutator.
http://lbfun.com/Corvette/Tech/vettetech.html
http://lbfun.com/Corvette/Tech/vette...%20Rebuild.pdf
I did lightly glass bead the housings to clean them up. They came out great.
I was hoping this task might be a little simpler...like maybe a well aimed squirt of WD-40 or Silicon spray to kind of loosen things up! But we all know it's never something that simple!
If I had to do it again, I'd disconnect the hood support, allowing the hood to open more than normal, and then I'd prop the hood up in that "over opened" position.
Oh yeah, the headlight motor disassembly, clean, assembly bits were quite easy and very rewarding when my headlights both worked for the first time.
Jeff
Normal position:
Without support attached:
