Differential ring verification
Old Nov 8, 2007 | 11:22 AM
raytex's Avatar
raytex
Default Differential ring verification
How can you determine if the ring and pinion are correct for the housing code of a rear end.
I have an 1965 differntial with code AP 12 21 64 on the housing which is a 4.11 I believe.
On the ring I can find several numbers one set is 32-4-63 the ring has 32 tooth.
Is this the correct ring for 4.11?
I also have a 71 rear end which reads LR which is a 3.36 I believe. the ring reads 373590 1 1:37 GM and has 37 tooth is the correct ring for a 3.36?
Old Nov 8, 2007 | 03:45 PM
knight37128's Avatar
knight37128
Do not mix and match ring rears and pinion gears.
You have to have a set. Count the number of teeth on both ring and pinion; now divide number of ring teeth into the number of pinion teeth.
Old Nov 8, 2007 | 04:00 PM
vark_wso's Avatar
vark_wso
Ring and pinion gears are (were) as assembly. Differential carriers may have had internals changed over the years, so the ratio codes may not be meaningful. What will work is counting ring teeth and dividing by pinion teeth. A 4.11:1 has 37 ring/9 pinion = 4.11.
If you have the 32 tooth ring (& 9T pinion) as appears in your post, that's a 3.55:1. (That's the only application for 32 tooth ring).
37 tooth ring gears, on the other hand, were used with 9, 10, 11 or 12 tooth pinions, so the ratio achieved could be 4.11, 3.70, 3.36 or 3.08:1 respectively.
Old Nov 8, 2007 | 06:03 PM
raytex's Avatar
raytex
Thx for the info
You are right I counted them with the 32 tooth ring it has 9 tooth on the pinion so a 3.55.
Code on the housing reads AP which according the Corvette Chassis and restoration guide is a 4.11 from a 327.
Someone in its 42 year life must have change them I guess
Should have done this home work before I bought the 71 BB 3.36 (37/9) rear end.
Not much difference between a 3.55 and a 3.36.
Old Nov 8, 2007 | 07:35 PM
JohnZ's Avatar
JohnZ
The ring gear has the tooth count for both the pinion gear and the ring gear stamped on it. In your '71 example, it's 11:37. On your first example, there's another number stamped with the "32" if you look closely - that's the pinion tooth count.
To Differential ring verification
