Fuel Stabilizer
Old Nov 12, 2007 | 09:56 PM
54greg's Avatar
54greg
Default Fuel Stabilizer
What brand do you recommend?
Old Nov 12, 2007 | 10:18 PM
Jimbo64's Avatar
Jimbo64
St. Jude Donor '09
sta Bil Have used for years----have had 0 problems Good luck
Old Nov 13, 2007 | 05:27 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I use it in classic cars, boat & jet ski for winter storage.
Old Nov 13, 2007 | 06:58 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Never needed any for winter storage or MUCH longer. Just started my car hauler that had been sitting for 2 years due to a major problem. Started in a few cranks and ran fine after a few moments.
Old Nov 13, 2007 | 08:05 AM
Frankie the Fink
Army
Lucky man - However, I spent a few hours drifting around the Chesapeake Bay because my buddy decided to set sail with fuel that had sat in his outboard all winter with no protection....not fun.
I say $5 worth of stabilizer is worth not having to possibly rebuild a carburetor, etc.
Old Nov 13, 2007 | 08:26 AM
kenmo's Avatar
kenmo
That's what I use as well....
Old Nov 13, 2007 | 12:38 PM
JohnZ's Avatar
JohnZ
I've garage-stored my "toys" through the 6-month Michigan winters for over 30 years without fuel stabilizers, and have never had any sort of fuel system issues. 2-cycle engines seem to be more likely to have problems without stabilizers.
Old Nov 13, 2007 | 12:54 PM
Cobra66's Avatar
Cobra66
I've used StaBil for years on just about every gas-powered vehicle or tool. However, I forgot to add a bit to my chain saw when I last used it about 9 months ago and this past weekend it started after just a few pulls.
The chain needed sharpening, but the bugger ran OK!
Old Nov 13, 2007 | 01:08 PM
67vetteal's Avatar
67vetteal
I'm on the "Not Necessary" side on this issue. Winter storage is not enough time for Fuel to go Bad. As for the issue with small engines, outboards, lawn mowers etc. all you need to do is run the Carb. dry for winter storage. The Passageways in these engines Carburetors are so small that the residue left behind by evaporated Gas, (commonly called Varnish), clogs the fuel flow. I always do my first run of the season on my small engines with just a small blast of Ether. Al W.
Old Nov 13, 2007 | 07:44 PM
OldKarz's Avatar
OldKarz
From: On the bank of the Columbia River..... Washington State
Old Nov 13, 2007 | 10:46 PM
54greg's Avatar
54greg
My toys have had to sit for the last two months due to road access problems and it sounds like my concern is not well founded. I've just been very careful to put the vehicles in rotation driving them at least monthly in the past. As always, thanks to all for the thoughts
Old Nov 14, 2007 | 12:15 AM
John McGraw's Avatar
John McGraw
I have never used it on any of my engines. The only problems that I have ever had was on 2 stroke engines, and I now just run them dry at the end of the season.
Regards, John McGraw
Old Nov 14, 2007 | 12:57 AM
327Heaven's Avatar
327Heaven
Although I've never had problems in the past with old gas in my cars I've jumped on the Sta-bil bandwagon just for the piece of mind. I actually started up my Mercedes about 2 months ago which had been sitting for almost a year and a half AND with old gas in the tank to boot. No problems since. For my carbureted 64, I'll use the Sta-bil.
I'd never do that with my gas power tools though.
Old Nov 14, 2007 | 01:03 AM
1BAD-LS1's Avatar
1BAD-LS1
I agree with John Z. I have been storing both the 2001 and the '64 from November to May in my non-heated garage over the winters in NJ with no problems, and no stabliazer. Good luck so far, I just top off the tank to prevent unwanted moisture.
Old Nov 14, 2007 | 01:04 AM
ffas23's Avatar
ffas23
I never use it in any of my collector cars. About the only place that I use it anymore is in my electric generators that I have for emergency since I may not use them for a long time. Some aren't used for years. I put a little in my snowblower also.
Old Nov 14, 2007 | 01:10 AM
YesA59's Avatar
YesA59
The guy who rebuilt the carbs on my 54, Bob Kunz, strongly recommended that I run racing gas in my 54. He claimed that the 3 carb 6 cylinder 53-54 corvette would run better on racing gas. He also told me that racing gas takes a lot longer to go bad than pump gas.
My 54 barely ran when I purchased it - the gas had gone bad from the tank forward. I had to restore the gas tank, change the fuel lines, and rebuild the carbs. Based on this experience, I now only run racing gas in my 54.
I'm not going to claim that my 54 runs like a scalded rabbit. But the car does run better than any 53 or 54 that I have been in so far.
Russ
Old Nov 14, 2007 | 10:39 AM
kenmo's Avatar
kenmo
I also add fuel de-icing stuff to my tank... Also supposed to aid in keeping moisture out...
Old Nov 15, 2007 | 04:09 AM
sweet66's Avatar
sweet66
Default fuel and time
gasoline over time will lose it's volatile components .. high octane just lasts longer than regular gas so unless the vehicle sits for more than 6 months
stabil should not be required..[I'll assume even owners of 63-64 250 hp mtrs use premium fuel..] regular gas in weedeaters and other small engines which sit unused for long periods are another story as per previous posts.. i have a outboard that sits for 10 months between seasons and for $5 stabil goes in the tank every time it gets parked away..
Old Nov 15, 2007 | 09:38 AM
Plasticman's Avatar
Plasticman
Ken,
Don't know if you guys north of the border are using Ethanol diluted fuel, like most of the US.
If you are, then the deicer is already in the fuel (it is the Ethanol).
Having had a 50 gal. tank of gas (4 cycle boat) turn into orange jelly over a 6 month span, I firmly believe in using Stabil.
A tad of prevention would of been well worth it.
Plasticman
To Fuel Stabilizer
