C-1 under dash
Old Nov 18, 2007 | 01:10 PM
babylonvette's Avatar
babylonvette
Default C-1 under dash
i have built a few solid axle cars over the past 10 years and while under the dash of the latest one , a 59 it seems that the framework under the dash , door pillars, and reinforcements are made of allumium ,when did they start or stop using it ,the last car i crawled under the dash was my 61 and i sanded and repainted all the frame work with por15 so it wouldn;t rust ,i did it with the nose and dash off, i never checked it for metal content i guess thats why it was in really good shape for being left in a field for 20/30 years
Old Nov 18, 2007 | 01:36 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
my 62 is definitely not aluminum under the dash...
Bill
Old Nov 18, 2007 | 03:12 PM
Plasticman's Avatar
Plasticman
Bill
Nope, mine is not either. It be rusty steel.
Plasticman
Old Nov 18, 2007 | 03:36 PM
John McGraw's Avatar
John McGraw
There is a mixture of steel and aluminum under the dash.
Regards, John McGraw
Old Nov 18, 2007 | 03:59 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
I had a 60 body which had some metal supports. Then a 61 had aluminum. The 62 had metal supports.
Old Nov 18, 2007 | 05:22 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
I was told 58 and 59 had all aluminum. Don't know for sure though.
Old Nov 18, 2007 | 05:29 PM
56Heap's Avatar
56Heap
I believe they started installing the supports in 57...maybe around vin 4296 according to Noland's book page 138
Old Nov 18, 2007 | 08:49 PM
TopLess62's Avatar
TopLess62
Plasticman
Mine be rusted steel or very sharp pieces of poop or nothing at all where i vacuumed it out. My horizontals are gone on both sides on the bottom.
I am lucky enough to have a full aluminum piece that i plan to use as a template to make some new pieces. I am surprised they used aluminum first and then changed to steel.
When i bought my car, there was standing water in the pockets from being kept outside for years.
Old Nov 19, 2007 | 11:11 AM
jimh_1962's Avatar
jimh_1962
The person who is doing my bodywork fabricated template plates for one side. I am sure he could use the same template to make another set.
Old Nov 19, 2007 | 12:02 PM
Romulus1960's Avatar
Romulus1960
My underdash looks like it rolled off the factory 47 years ago. I wish I could say the same for the rest of the body.
I assumed it was steel as I read (first mistake ) that only 58 had an aluminum cage.
I honestly thing most of the damage to this car came from getting bumped around in a garage for 30 years.
Old Nov 21, 2007 | 12:04 AM
babylonvette
thanks guys for replying, i just thought it was strange to have allumium under the dash, you never know unless you ask thanks for the responces
Old Nov 22, 2007 | 01:01 PM
JohnZ's Avatar
JohnZ
Mine was #4275, and had the aluminum bracing - must have been pretty close to when it began.
Old Nov 23, 2007 | 03:06 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Has aluminum suddenly been declared to be a plastic or something?
Old Nov 25, 2007 | 09:35 PM
Vindog9's Avatar
Vindog9
Default Aluminum
I have a early 58 and it is all aluminum!
Vindog
Old Nov 26, 2007 | 09:09 AM
kenmo's Avatar
kenmo
My 60 is metal.....
Old Nov 26, 2007 | 03:30 PM
dgsmith's Avatar
dgsmith
It's late in this thread to comment but I've learned over the years that Chev. started adding undercowl-door pillar and door supports made of aluminum during mid-57 prod. because of sagging doors and cowl areas. Sometime early in '58 they switched to steel, which was continued through 62. Aluminum supports in a 60's vintage car, I can't explain. Maybe switched in sometime during history of car.
Old Nov 26, 2007 | 06:26 PM
vetteman19's Avatar
vetteman19
Default 58
Do you knw of a 1958 project? I have ll new chrome and need a car to place it on..Hope you had a nice Thanksgiving..
To C-1 under dash
