More porn
Nov 18, 2007 | 06:04 PM
More ****
Nov 18, 2007 | 06:06 PM
Your post title sure got my attention!
Beautiful pics--keep 'em coming.
Nov 18, 2007 | 06:18 PM
Hey, where's the ****?? All I see is the engine.
Nov 18, 2007 | 06:20 PM
Quote:
Originally Posted by
Trophy Blue
Just for you:
Nov 18, 2007 | 06:26 PM
Nov 18, 2007 | 06:40 PM
And just how high are those nice rockers going to lift up?
Doug
Nov 18, 2007 | 06:43 PM
Shurshot
Doug
I'm keeping it under .600 for valve train reliability and so I don't have to replace the springs as often.
Nov 18, 2007 | 06:49 PM
From: One thing is for sure this kind of discourse and BS would not be tolerated on the NCRS forum. Ohio
You should really clean that intake up and torque that head bolt....
knight37128
sissy la-la
Nov 18, 2007 | 07:09 PM
Duntov-097
Notice that too.
Nov 18, 2007 | 07:10 PM
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I always had a fondness for big blocks.
Whar are your cubes, CR and cam?
Doug
Nov 18, 2007 | 07:15 PM
Man, she looks really good. Makes me miss my old GM heads.
Very sweet looking. Keep the pics coming as you get her installed in the car!
Nov 18, 2007 | 07:40 PM
Duntov-097
The intake is not bolted up, yet. The head bolt is torqued after I put the teflon on it.
Nov 18, 2007 | 07:49 PM
AZDoug
Doug
505ci, about 9:1 (flat tops), and the cam is a Crower solid roller. .581 intake lift and .573 exhaust lift.
Nothing too radical for the street........................
Nov 18, 2007 | 09:39 PM
Gimme a bore/stroke, cam duration at .050" and LSA, and I will EA it for you. Header/muffler/exhuast helps also.
Doug
Nov 18, 2007 | 09:48 PM
2021 C1 of the Year Finalist - Modified
4.310 X 4.25 w .100 dome piston ???? Off the top of my head guess ?
Nov 18, 2007 | 09:49 PM
AZDoug
Doug
Bore 4.35
stroke 4.25
Intake: 242
Exhaust: 250
Factory side pipes............... stock manifolds, 2 1/2 side pipes.
850 cfm carb worked over a little bit.
Nov 18, 2007 | 09:57 PM
From: Where everyone's grandparents come to die, FL
Trophy Blue
This was a BIG letdown.
Nov 18, 2007 | 10:13 PM
You cut the nuts off it with that exhaust system. That suckers gotta breathe !
Nov 18, 2007 | 10:26 PM
Pop Chevy
I know................. Maybe in the spring I can upgrade.
I am working on how to run it out the side and the back. A true dual exhaust.
