A/C Drier
Old Nov 20, 2007 | 06:48 AM
Tschim's Avatar
Tschim
Default A/C Drier
I bought an old correct drier for a 67 but is there any way to test it prior to installation? Thanks
Old Nov 20, 2007 | 07:27 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
if the inlet and outlet ports of the drier are/were not plugged/tightly sealed; the chances are the drier has absorbed water and is no longer good. if it was sealed, and it isn't physically damaged, then it should be good to use. you will know if it leaks when you pull a vacuum on the system when it is being charged.
Bill
Old Nov 20, 2007 | 07:53 AM
67L36Driver's Avatar
67L36Driver
Default Suck out the moisture.
If you keep the system under a vacum long enough, any moisture will be eliminated. Overnite (12 + hours) should do it.
Old Nov 20, 2007 | 08:03 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
yep, you may get the moisture out; but there is no guarantee that long term exposure to moisture has not damaged the internals of the drier....
Bill
Old Nov 20, 2007 | 09:39 AM
67vetteal's Avatar
67vetteal
Once exposed to the Environment the Dessicant inside your Drier will no longer be of serviceable grade. There is a company in Fla. that will refill your correct unit. They do cut it open and re-weld it. Don't short change on a Drier as it is the Defender of your A/C system. Al W.
(Also, here's a good place to learn about A/C. Search word, "Mitch". http://www.autoacforum.com/).
Old Nov 20, 2007 | 09:47 AM
62Jeff's Avatar
62Jeff
http://www.classicair.com/Default.asp
I used them to rebuild the drier and compressor for my 65, very happy with the results, and price. $68 to rebuild my drier.
Old Nov 20, 2007 | 01:09 PM
yesfam's Avatar
yesfam
The dessicant bag is only designed to absorb about a teaspoon of water. When the material has reached it's saturation point it will begin to break down into a powder and will contaminate the system. Get it rebuilt, install it immediately, vacuum the system completely and then recharge for the best results. A small amount of oil should also be added when replacing the drier. I believe about 1-2 oz. should be sufficient.
Old Nov 20, 2007 | 01:53 PM
67vetteal's Avatar
67vetteal
At this point it would be wise to Flush the system and recharge from Scratch. Lacquer thinners or Mineral Spirits are used to Flush the system. Do your homework before starting this proceedure. It can be done by a Do it Yourself mechanic. Recommended amount of Mineral Oil is 11 Onces (5 Compressor/6 Condensor). Al W. .
Old Nov 20, 2007 | 08:37 PM
Tschim's Avatar
Tschim
Thanks very much for all the input!
To A/C Drier
