comments on Supertech brake fluid??
Old Dec 3, 2007 | 01:07 AM
LT1driver's Avatar
LT1driver
Default comments on Supertech brake fluid??
dot 3....is this brand any good, etc. , available at wally world in gallon and I need to do several brake flushes otherwise I go with dot 3 by prestone, castrol etc.
Old Dec 3, 2007 | 01:16 AM
ffas23's Avatar
ffas23
Dot 3 brake fluid is made by many different manufacturers and is made to Dot 3 specifications. I wouldn't worry about it. It doesn't have to say Castrol or Prestone on it to be good Dot 3 brake fluid. Just make sure Dot 3 brake fluid is what you have in your brake system. Many Corvette owners over the years switched over to Dot 5 Silicone Brake Fluid and the two don't mix. If you mix them not knowly you will have problems. Make sure first as to what you have in your system. If you know you have Dot 3 in your system you are good to go with the Dot 3 Brake Fluid Wally World will sell you.
Old Dec 3, 2007 | 04:46 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
Bill
To comments on Supertech brake fluid??
