I have a 66 vert with a 4 speed. Due to the health of my left leg I am considering an change to a automatic so I don't have to work the clutch... will a 350 or 400 auto fit in this car? Anyone done the conversion...
Any chance your car has a stiffer than normal clutch? Just a thought.
When I bought my car it had a hi-performance clutch which I had removed and a factory type clutch installed. Still stiff but only about half as much. Maybe you can convert to one of those hydraulic clutches?
That may be an option, but I really think I will be wanting an auto soon. How does the powerglide hold up to horse power...
Capt Roy
I have two powerglide 67's - one with a 427/390 and one with a 327/300 engine. I much prefer driving them over 4 speeds as my legs are well over 60 years old. I find that when driving a powerglide car with the high horsepower (high torque) engines, the powerglide is really quite impressive - the high torque seems to offset the inefficiencies of the transmission. I've been told that the powerglides are used by drag racers because they are virtually indestructable in high horsepower applications.
To your original question - if you value originality, why not stick with a glide?
A properly prepped powerglide will hold up to high horsepower. The powerglides that are use in drag racing with high horsepower will cost you 2-4 thousand.
Now for street use I would go with a 200-r4. You will have overdrive, lower first gear and a lockup torque converter. A 200-r4 out of a buick Grand National in stock form will handle 400-500 hp motor and will give you better street performance and gas mileage. Spend 2-4 thousand and it will hold up 1000hp.
At the drag strip the powerglide would be fine but for the street the 200r4 is better.
