Electrical help please!!
Shooter
Hope it doesn't sound too confusing.
http://s131.photobucket.com/albums/p...t=PICT0224.jpg
The other one is probably the wiper ground, should be on the ignition harness. Should be black. Might want to use an ohm meter and verify it is ground first, should be 0 ohms across the engine.
Shooter
The thumbnail photo shows the wiper motor ground spade - it's in the center of the photo, under the same screw that attaches the wide copper ground strap to the motor case.
Shooter
Shooter
gotta keep everyone happy you know)
. Anyway the ground wire was no problem, I found the right female connector and plugged it in. I did follow the ground wire out John like you suggested and it was the same one that led to the heater and starter. Next, the back-up switch. Raised the car and
searched.....
and searched................
and searched. YIP, YOU GUESSED IT, you can't find something when it's not there.
I guess when "my buddy
(previous owner)"
said he restored the frame So now any suggestions on where to get a good switch and evrything needed to put one on?
There's nothing there except the bolt holes. Need one that will pass judging so if anyone has one for sale or know which vendor reproduces the right one I'd appreciate the information. Thanks John and bweaver999 for your help. Take care,
Shooter
Jerry I won't have to worry about jacking the car up, I bought a lift for the restoration. The old knees don't work the way they use to. Thanks again.
Shooter
