Fuel Pump Question
Old Dec 17, 2007 | 12:18 PM
salty_waders's Avatar
salty_waders
Default Fuel Pump Question
I have a 65 327/350hp. The new fuel pump I have and was planning to use is listed for a 327/300hp. Can I use it? Do they both pump the same amount of fuel?
Old Dec 17, 2007 | 12:39 PM
JohnZ's Avatar
JohnZ
The only variable is the orientation of the inlet and outlet ports and type of fittings; both pump the same amount of fuel.
Old Dec 17, 2007 | 01:03 PM
salty_waders
Are the fitting sizes the same? I mean the thread sizes. I have a pump for a 350hp but the steel line from the pump to the carb wouldt work becuase outlet on the pump was too high and the steel line was too tall above the filter. It looks like the outlet on a 300hp pump is lower and should work if the fittings are the same size. Any pump recommendations?
To Fuel Pump Question
