My sidepipes outside diameter measures 2 3/4" so do I have 2 1/2" sidepipes? If so, if you figure the chambered area, would they be down to 2" ? Is there some kind of inner chamber and any way to determine that size (diameter)? Also, any way to tell if they are Allen's, Sweet Thunder, or ??? Yes, I know it's a dumb question but after seeing MasterDave cut his open, I am now very curious. And no, I don't want to cut mine open Thanks guys
Do you have 2" exhaust manifolds or 2 1/2" exhaust manifolds? Thats how you tell....I believe (but I am sure I will corrected if I am wrong) that the pipes themselves are the same size its just at the exhaust manifold that is different.
My Allen's 2 1/2" pipes have an OD of 3", I think you may have either 2" or 2 1/4" ID pipes.
Just because the exhaust manifolds are one size doesn't determine the ID of the chamber, ie the originals were 1.75" ID with either 2" or 2 1/2" exhaust manifolds.
That was exactly my point......like I said the pipes were the same size....what determines if you have 2" or 2 1/2" is the exhaust manifolds....
Thanks Scott, with you help we figured out my pipes are Sweet-Thunder 2 3/4" with 2 1/4" baffle.
