How do these numbers look?
Old Dec 27, 2007 | 08:31 PM
Countryking's Avatar
Countryking
Default How do these numbers look?
Engine Casting 3756519
Casting Date I229
Pad F0930CT
VIN 00867S101185
Rearend 374883 or 374733
Old Dec 27, 2007 | 09:32 PM
62Jeff's Avatar
62Jeff
The Birthday calculator located at
http://www.ncrswi.bizland.com/bday/bdaycalc.htm suggests a vehicle assembly date of approximately Nov 3, 1959
The engine casting date appears to be September 22, 1959
Engine assembly date is September 30, 1959
However I believe this is the same engine that JohnZ suggested had a suspicious, atypical stamp leading us to believe it isn't truly the original engine for that car.
Old Dec 27, 2007 | 09:42 PM
Countryking
Yes this is the same. I just got the casting date. It could be the correct engine. The stamp may be in question. How would this car fair with the correct casting date and since its a 519 block. This maybe the correct engine but the pad was milled during a rebuild? I have seen a lot of 60 vettes with NOM all listing around sixty or higher?
Old Dec 27, 2007 | 09:43 PM
62Jeff's Avatar
62Jeff
that vin is for either a 63 or 64. the op need to fill in the first two digits of the vin for us or fill out his profile
No, it's for a 1960.
The VIN of my 62 is
208672114120. The first digit indicates year
Old Dec 27, 2007 | 09:44 PM
62Jeff's Avatar
62Jeff
I'm going to have to defer to someone who's actually an NCRS member to offer detailed guidance.
Old Dec 27, 2007 | 09:46 PM
Countryking
VIN 00867S101185 (this is a 1960) 00
Old Dec 28, 2007 | 04:32 PM
JohnZ's Avatar
JohnZ
350 points are allocated to the block. In this example, you'd lose 88 points for the pad; 50 for the non-typical engine plant stamp, and 38 for the non-typical pad surface. You'd get full credit for the casting number and casting date.
Old Dec 28, 2007 | 06:57 PM
John McGraw's Avatar
John McGraw
Also, I might be incorrect, becuase I am too lazy to go look it up, but I think that that date engine should not have a VIN deravitive on it. I don't think that started VIN stamping until late in November or early December. The early 60 engine stamps looked like they were stamped by a drunken sailor with the shakes! They did not use gang stamps, and all the digits were stamped individually.
Here is how a correct early 60 stamp should look, but I think that that date is way too early to be wearing a VIN. This is the engine stamp of my Duntov 60, and the engine had never been apart before I bought it.
http://img.villagephotos.com/p/2003-...3/P0000170.jpg
Regards, John McGraw
Old Dec 28, 2007 | 07:11 PM
John McGraw
Sorry guys,
I went and looked at the original post, and the engine did not have a VIN stamp on it. I don't know how I came to the conclusion it had one!
In any case, I would agree with Mr Hinkley that the stamp is atypical.
To How do these numbers look?
