alignment issues-problem
too much toe-in/toe-out with correct camber should cause an even scrubbing of the tire tread off across the entire tire tread.
correct toe-in/toe-out with incorrect camber will cause tire wear inside or outside of the tire tread (depending on whether it's positive or negative camber)
Bill
As stated by wmf62, toe being really off can cause drastic wear, but it is across the face of the tire, and you normally also see feathering across the face as well.
here is a list of alignment caused issues as listed on Discount Tire web site:
http://www.discounttiredirect.com/di...oAlignment.jsp
Misalignment Condition = Tire Wear Symptom
Incorrect Camber Setting = Premature smooth wear on either inside or outside shoulder
Incorrect Toe Setting = Feathered wear across tread; raised tread block edges
Incorrect Caster Setting = Excessive shoulder wear; tread blocks show "heel-toe" wear pattern
Unequal Caster setting (either right or left side is out of specification) = Sharp pulling necessitates steering compensation and feathered wear
Unequal Toe setting (either right or left side is out of specification) = Sharp pulling necessitates steering compensation and feathered wear
Combination of two or more settings are out of specification = Irregular treadwear with feathering and smooth spots
And Toe-in is with the tires pointing inward at the front of the vehicle (a small amount is normal for street driving), and provides a stabilizing affect. Toe-out can be used, especially race vehicles where quick turning is required such as in autocross.
Plasticman
