What they are saying in the Black Book, "limited use", actually means "Limited Quantity of Units.
What the NCRS says is:
"A limited number of these small block engines (3858180 block) appeared in 1965 Corvettes. Their casting origin was Tonawanda, New York; apparently shipped to the Flint, Michigan engine plant for machining and assembly. Their usage is believed to be a substitution occurring during a foundry shutdown at Saganaw, Michagan."
If legitimately installed in your 65 Corvette, the pad on your '180 block would still bear an "F" in the engine assembly stamp since it would still have been assembled in Flint.
Many are not even convinced it happened. But if you have a properly stamped pad and a good casting date that makes sense, I'd love to hear more about it
ctjackster...... the only other numbers I find on the block are A 3 6.
Does that tell you anything?
that is found up near the firewall on the passenger side, correct?
looks to be a casting date code. January 3 1966 - would be a tad late for your 65.
Hopefully, you got that wrong, or it is found on some other component of your engine.
by the way, another forum member has a '180 block in his 64 (which makes that even more "rare"):
