What is the difference between a 1963-65 327/300 balancer and the one used in 1966? The parts manual lists different part numbers. Both balancers are 6" in diameter. Is it ok to use the 65 balancer on a 66?
The most significant change that occured to balancers was between 68-69. The timing mark on 68-earlier balancers is in-line with the crankshaft keyway. In 69, the timing mark was rotated about 10-12deg toward the Advance (A) mark. As a result, the timing cover with the correct corrosponding timing tab must also be used. The hard one to find is a 62-68 timing cover for an 8in balancer!!!
So, to answer your question, as long as you stay within the same family of balancer/timing cover, you'll be just fine. From my viewpoint, a 6in balancer is a 6in balancer and an 8in balancer is an 8in balancer (with its corrosponding timing cover).
As an example, if you were to install a 1975 8in balancer from a 350 engine onto a 1963 327 (or even a 283), you would just need to also use the timing cover from the '75 350.
That's fine for the timing aspect. I wouldn't think it would be wise to disregard the time/effort Chevrolet put into tuning balancers to individual applications. You can cause yourself some grief with crankshaft cracking problems.
No argument with that, I was only giving an example of the matching of a balancer/timing cover. Of course, if an engine is a "built" engine, then what balancer do you select????
That's a very good question and one I'm not prepared to debate. I've asked any number of engineers over the years how a harmonic balancer is tuned to the engine. Most reponses were just a shrug of the shoulders. I wish somebody could answer that in a manner everyone could understand.
One response I got from factory engine resident engineer, if you can believe this. Harmonics? Hell, I can't even play a ukelele!
I don't know how it's done, I just know the consequences of using the wrong one from the school of hard knocks.
How about this theory. 8" balancers were used on the more HP engines with somewhat more radical cams. I think the bigger/heavier balancers were used to "help" the hotter engines move out from a standstill more smoothly. Bob
I don't know the scientific answer either, but the GM drawings for balancers all show that the assembly must be tuned for 165-180 cycles per second at 150*F. Since a V-8 engine fires four times per revolution (and a torsional damper damps individual firing impulses), that would indicate that the dampers are tuned for an engine speed of about 2800 rpm.
2800 rpm = 46 rev. per second = 23 full V-8 firing cycles = 184 cycles per second.
The drawing also states that the polar moment of inertia of the outer ring must be 0.286 inch-pounds per second squared, but I've been out of college for too many years to deal with that.
I think this requirement on the print is key as to why some V-8's require different balancers than others. Example: 250/300 hp 327 vs. the SHP 327's.
But, since I never got past the 8th grade, I'm not prepared to deal with it either.
