I've got a suspect ground issue somewhere in my 64 coupe.
Can someone tell me where the ground straps are located. I've looked at the AIM and Chilton but couldn't find any reference. I've got a kit from Dr. Rebuild and I can find one at the front, underside of sill at the drivers side door. I've also got the remnants of one on the throtle linkage????? Is that right? Where else?
Maybe you should post what circuit you're having trouble with. With the exception of the ground at the #1 body mount, the others mentioned are radio static suppresion grounds.
