May be a basic question
Hello
After work I decided to take a quick drive to the auto parts store and started the Vett I admit I did not let her warm up Getting out the driveway the old girl stalled as I was giving gas and I could not get her to fire up again? The plugs have fire I have gas going into the carb I thought that she was flooded waited a few hours tried to start the car
The Vette is turning over getting fire and gas but will not start
I recently cahged the plugs and she was running great this weekend
Am I missing something? I guess I can check plugs for fowling other then that I havent a clue
Any advice would be greatly appreciated
Thank you
BuffaloBill
65 Vert
Thank you
BuffaloBill
65 Vert
Basic Question
The spark is bluish white/yellow ( Weak) Yes Electronic ignition
I will pull a couple of plugs this evening after I attempt to start up agian
Bill
Bill
Before you try to re-fire the engine, pop the hood and remove the aircleaner assembly. It probably flooded and you don't want it to backfire and damage the hood. If it's flooded, floor the accelerator (wide open) and crank it until it fires up. Then let it warm up normally. If your choke is closing up too far, the engine could have starved for air. Check your choke setting before doing anything. Could be as simple as a screw adjustment on the high step of the choke cam.
Moderator
Very possibly you've washed the cylinders with so much fuel that your compression is now too low for it to fire. Hood open, air cleaner off, throttle to the floor and choke open, crank while using starting fluid. If still no fire you will probably need to oil the cylinders a little by removing the plugs.
plugs
When you changed plugs did you change the brand or heat range?
If so put the old plugs back in and see if that works.
Weak coil ?
Ground wire broken in the distributer?
Weak coil ?
what about that white ceramic electrical thing ...... does this car have one......... they used to break at the weirest times on my old mopars.........cant remember what their called ......ballust resistor or something........mounted on the firewall......
Could be a stuck float in the carb not allowing gas to refill the fuel bowl. I've had this happen before. The fuel bowl in the carb has enough gas to let you run for 15 to 30 seconds before the engine dies and won't restart if it is stuck. Take of the air cleaner and see if the accelerator pump squirts gas in when you work the throttle. If it doesn't squirt, try rapping on the carb with a rubber mallet where the gas line enters the carb to see if it fixes it.
I would check the coil, especially if it is old. A weak coil will do that. I know because I pushed a 63 coupe about a quarter of a mile to get it home.
I would check the coil for enough spark or the distributor cap for a small crack or worn contact points. Any of these things will give you too weak of a spark.
Good luck!
Good luck!
Basic Question
Thanks for all the advice
Bill
Basic Question
JEFF 62 Please call me at my cell should you have a moment
Thank you
Bill
281-686-8095
Received 1,844 Likes
But you said it was getting spark to the plugs??????????????
If it is, I'd suspect you have gas fouled the plugs. When they get gas fouled, they'll spark outside the engine sometimes but when you put them back in the cylinder under pressure, they won't fire. If you pull a couple of plugs and they're wet, replace all of them and see if it doesn't fire right off.
Nice chatting with you. To respond to this thread - the middle wiring diagram is for a Pertronix II with a Stock rated coil, the idea being to drop the voltage to the ignition system to keep things from getting fried.
The bottom diagram includes the different coil with the different rating which does not require the voltage to be dropped to the coil.
If I got all that wrong, surely someone will step in and help me out.
Jeff
I'm with Mike....install a new set of plugs and I bet it fires up.
Danno
I will call Petronix tech line to ask if there is a possibilty that my Petronix is still good If not I will purcahse a new one.
Bill
St. Jude Donor '07
it will be a lot cheaper to go back to points than to replace the Petronix...
but, it's interesting that you have 12 volts in and 12 volts out of the ballast. it is a resistor, and if it fails, it should fail open (no voltage out); unless it is somehow bridged from end-to-end across its resistor coil.
Bill
Bill
Received 1,859 Likes
Disconnect the wires from both ends of the resistor and check across the terminals with a VOM set on "ohms" and tell us what you see; it should be between 1.5-2.5 ohms.
