Removing rocker panel clips
Old Dec 5, 2001 | 09:37 AM
GregP's Avatar
GregP
Default Removing rocker panel clips
Whats the best/preferred method for removing the rocker panel clips to make room for side pipes? (I have to use side pipes, there is no room under the car for a "normal" exhaust system).
-Greg
Old Dec 5, 2001 | 10:04 AM
GreaseMonkey's Avatar
GreaseMonkey
PA Events Coordinator
Default Re: Removing rocker panel clips (GregP)
Greg,
The best way would be with the body off. I had to replace some and repair a couple areas around them on my '64. They are welded in the back of the channel under the door sill as well as in the front. I took a grinder and ground the welds to free them.
If you're not pulling the body, then I'd just take a cutoff tool and cut them off.
BTW, what side pipes are you using? I just got a set of Hookers, and they don't even require the clips to be cut off. I got mine from JetHot in their silver luster finish. They look awesome sitting in the box and should look even more awesome on the car. Great price too.
Did the dash drawing work out ok?
:cheers:
[Modified by GreaseMonkey, 8:05 AM 12/5/2001]
Old Dec 5, 2001 | 02:19 PM
GregP's Avatar
GregP
Default Re: Removing rocker panel clips (GreaseMonkey)
I can't actually remove the body, just lift it up a few inches, as there isn't enough room in the garage to lift it up over the roll cage (and no place to put it if I did get it off anyway).
I'm planning to fabricate my own side pipes (what else is new), as with the set-back motor and stretched wheelbase and rocker panels, stock ones wouldnt' fit. Also, I have to go from the exhaust ports and over the frame rails, as there is no room under them (the ground gets in the way :) ). I plan to tuck the pipes part way under the body and pretty close to the frame rails, so it looks like the clips will have to go. I hve some 4" stainless pipe on the shelf (old boat exhaust) that I've been using to mock things up to look for clearances.
The dash template worked great, I have the mock-up drivers panel in now so I can check steering column clearances for setting the brake mount, mid motor plate, cage cross brace, .........
Thanks - Greg
Old Dec 5, 2001 | 05:25 PM
GreaseMonkey
then I'd just cut em off.
Old Dec 5, 2001 | 06:54 PM
Kid_Again's Avatar
Kid_Again
you do not need to cut off the clips if you're using repros that match the factory originals
To Removing rocker panel clips
