Timing
Old Feb 23, 2008 | 10:43 PM
1965FI's Avatar
1965FI
Default Timing
I put a timing light on my car for the first time and with the engine running the mark on the pully was TDC. Was does that mean. I did have the timing light connected to the #1 plug wire. How do I resolve this?
Old Feb 23, 2008 | 11:17 PM
Bill Irwin's Avatar
Bill Irwin
Did you disconnect and plug the vac can? If so, and you were at 0*, loosen the dist bolt and turn the dist counterclock wise until you see 10* BTDC. Lock down the dist, and you should be good to go. Reconnect vac hose. Bill.
Old Feb 23, 2008 | 11:21 PM
1965FI's Avatar
1965FI
I disconnected the vac hose but I didn't plug it.
Old Feb 23, 2008 | 11:22 PM
62Jeff's Avatar
62Jeff
I wonder if that bad timing may be the source of the pinging from your other post.
Old Feb 23, 2008 | 11:24 PM
Bill Irwin's Avatar
Bill Irwin
You must plug the hose, anything will do, a pencil, ball point pen, etc. Bill.
Old Feb 23, 2008 | 11:25 PM
1965FI's Avatar
1965FI
I did loosen the dist and try to turn. I seemed impossible to move. I would think if it was out of timing that far it wouldn't run at all. Is it possible the pully was installed wrong?
Old Feb 23, 2008 | 11:28 PM
1965FI's Avatar
1965FI
would the not plugging the hose create the wrong read of the pully mark?
62Jeff's Avatar
62Jeff
Well, technically no, but there could be a different problem.
I'm no expert (standard internet weasel disclaimer) but I remember reading here on the forum that if the timing chain cover is not matched to the harmonic balancer, then the timing mark on the balancer will not correctly align with the timing tab on the chain cover.
Something about early model balancer versus late model timing chain cover.
However I don't remember if the mis-match would result in the timing appearing too far advanced, or too far retarded.
Here's the thread that discussed it, but I can't tell from the details in this thread where the timing mark would end up in relation to the tab on the timing chain cover, if your timing was at about 8 or 10 degrees advanced, but you used the mis-matched components
http://forums.corvetteforum.com/show...er+mark+timing
It is also possible that all of your components are correct, but maybe the outer ring of the balancer slipped in relation to the inner ring due to a failure in the rubber layer that bonds the two together.
Old Feb 23, 2008 | 11:52 PM
Plastic Pig's Avatar
Plastic Pig
Live Free or Die
From: One thing is for sure this kind of discourse and BS would not be tolerated on the NCRS forum. Ohio
You're never gonna turn a fuelie distributor by loosening the hold down.
Old Feb 23, 2008 | 11:54 PM
62Jeff's Avatar
62Jeff
What's the trick? I know the fuelie distributor is different, but I can't put my finger on what the difference is. Does it also drive a pump in the fuel unit or something?
Old Feb 24, 2008 | 12:07 AM
Plastic Pig
Live Free or Die
You can't rotate the distributor due to the cable that drives the high pressure pump needs to line up with the distributor. There is a pin that locates the distributor so it can't move.
There is a band on the distributor that you loosen and then you can adjust timing.
Old Feb 24, 2008 | 01:12 AM
62Jeff's Avatar
62Jeff
Cool. Thanks for taking the time to clarify.
To Timing
