quick shift location
Old Mar 5, 2008 | 07:41 AM
geo65's Avatar
geo65
Default quick shift location
I'm assembling the trans linkage what's your preference on the shift lever location? I assume the top is longer throw, easier movement and lower opposite.
Old Mar 5, 2008 | 07:56 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
I don't know about anyone else but I changed mine from the original long throw setting to the short one. I also favor the Hurst unit over the original linkage. I could never get the original linkage to give me a positive feeling when I wanted to speed shift the car. Hurst takes care of that. JMO
Steve
Old Mar 5, 2008 | 07:57 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
that is EXACTLY the case; all i can suggest is to try it and see which set of holes you can live with...
Bill
Old Mar 5, 2008 | 08:12 AM
MikeM's Avatar
MikeM
Steve
You want opinions?
Mine is just the opposite from above. But I don't pull any power shifts anymore. Too much chance of breaking something. Don't like Hurst shifters either. They're fine on a race car. They don't belong on a street car.
The stock shifter shifts nice and smooth in the "long" holes.
Old Mar 5, 2008 | 09:18 AM
sting ry's Avatar
sting ry
I prefer the "short" throw option. A properly maintained and adjusted stock shifter will give nice crisp shifts.
Cheers
Steve
Old Mar 5, 2008 | 10:09 AM
66since71's Avatar
66since71
Cheers
Steve
In the short throw holes it did not seem significantly harder to shift than my 1992 6 speed.
Old Mar 8, 2008 | 02:49 PM
Frank Hermann's Avatar
Frank Hermann
I read your question and am wondering, can you change from a long throw to a short throw with the standard shifter and how as I would like to do that to mine. Does it show how in any of the manuals or can someone easily explain.Sounds like a good project to do before it comes out for spring training,Thanks Frank
Old Mar 8, 2008 | 03:20 PM
MikeM's Avatar
MikeM
Look at the 1-2 and 3-4 shift arms on your transmission side cover. If there is another set of holes in the arms besides the ones your existing clevises are in you can make a change. The holes closest to the shift shaft will give the shortest throw on the shift lever.
You may have to re-adjust your linkage if you change it.
Old Mar 8, 2008 | 07:33 PM
ghostrider20's Avatar
ghostrider20
The shifter rods are in the "Long" or slow shift position in the pic.
Mark
Old Mar 8, 2008 | 07:45 PM
steve jarrett's Avatar
steve jarrett
I had my linkage in the "short" configuration for years, changed it to the holes further from the attachment poing. It's easier to shift and smoother in my opinion. Steve
To quick shift location
