Horn problem
Old Mar 9, 2008 | 09:22 PM
riverview112's Avatar
riverview112
Cruising
Default Horn problem
I have a 58. I am trying to repair my horn. I have power to the horn relay, but neither horn honks. I tried replacing the relay and that didn't work. I tried adjusting the nut on each horn in and out, but still no noise. I was thinking of bypassing the relay and running some jumpers directly to one horn. Anyone have any ideas or heads up of what might happen? Thanks.
Old Mar 9, 2008 | 09:30 PM
SunsetC6's Avatar
SunsetC6
Check your wires at the horn connectors also (you may have done this already) to make sure you have power all the way to the front. Could be a problem with the contact in the wheel or a ground wire so be sure to check that out. Hope this will help. I had a friend with this problem and it was the horn button.
Old Mar 9, 2008 | 11:15 PM
1955 copper's Avatar
1955 copper
2015 C1 of Year
That will tell you if thier good and working
Old Mar 10, 2008 | 07:29 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Make sure your horns are grounded well (usually via their mounting point) and touch a jumper from the pos side of battery to the wire on either horn. If it blows its wiring problems; if not dig deeper into the horn itself.
To Horn problem
