alternater
Old Mar 10, 2008 | 06:39 PM
bmcnitt's Avatar
bmcnitt
Default alternater
How can you test to see if your alternator is working?
Old Mar 10, 2008 | 06:42 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
You can pull the alternator and take it to an auto parts store and have it bench tested. That isolates it totally and lets you know if it is working properly or not.
Rich
Old Mar 10, 2008 | 06:44 PM
Plasticman's Avatar
Plasticman
If it is still mounted and connected in the Vette, then get out a Volt Meter, and attach it across the battery.
With no load (doors closed so the interior lights are off, key off, etc.), the battery should be around 12.6 volts.
Start the engine, while the volt meter is still connected, and the voltage should be higher (somewhere north of 13.5 volts on up to 15 max.). As the battery gets charged (from being discharged from running the starter), the voltage should drop to around 13.5 to 14.1 volts.
Plasticman
Old Mar 10, 2008 | 07:24 PM
62Jeff's Avatar
62Jeff
Start the engine, while the volt meter is still connected, and the voltage should be higher (somewhere north of 13.5 volts on up to 15 max.). As the battery gets charged (from running the starter), the voltage should drop to around 13.5 to 14.1 volts.
Plasticman
Wouldn't one possible outcome of a bad regulator result in 12.6 or fewer volts with the car running?
Old Mar 10, 2008 | 08:14 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Maybe -- but I think this test is for the 'goodness' of the alternator; if it passes then the electrical system checks out. If the voltage is low then it could be the alternator or possibly something else.
Old Mar 10, 2008 | 08:30 PM
plaidside's Avatar
plaidside
Check this article I wrote, it should answer any question you might have.
http://temp.corvetteforum.net/classi..._Testing.shtml
Old Mar 10, 2008 | 10:23 PM
Plasticman's Avatar
Plasticman
Exactly correct.
Thanks Frank,
John
Old Mar 10, 2008 | 11:28 PM
Ironcross's Avatar
Ironcross
Excessive voltage is a indicator of a bad regulator. This condition results i lamps blowing out. OR full field the alt to see if that's working correctly. However your system should not have a integrated {intrinsic} regulator. Those came in later years.
Read Plaidsides article
Old Mar 11, 2008 | 05:10 PM
bmcnitt's Avatar
bmcnitt
I ran the car today and had a reading of 14.8 volts across the battery so it looks like the alternator is fine. Thats the good news, bad news is it looks like I have a wiring short. I have another thread going right now ("goofy battery/electrical problem") were I have been getting some real good advice on how to go about isolating my problem. Probably going to take a little work and a lot of luck. Installed a quick disconnect on the battery so I can at least go out there and drive around as we are getting up into the mid 60's all week.
To alternater
