Heater Indicator Light
Old Mar 17, 2008 | 09:26 AM
gask99's Avatar
gask99
Default Heater Indicator Light
New to the forum........ 1966.....I had my radio out being fixed, and I noticed a wire hanging down. The body is silver with a green lens. Somebody told me it was the" heater indicator light". Can anybody tell me if this is correct, and where does it get attached to.
Thanks,
Tom
Old Mar 17, 2008 | 09:41 AM
62Jeff's Avatar
62Jeff
Welcome!
If your car does not have factory A/C, then that bulb is the backlighting for the Heater and Radio **** lettering, and it normally clips to the dash housing that holds the clock, at the 6 o'clock position.
If your car has factory A/C, then it could also be one of the 2 additional lights of the same style, that provide the backlighting for the A/C and Temp **** lettering. Those additional lights clip on the to the dash around the perimeter of the clock area at about 9 and 3 o'clock position
Old Mar 17, 2008 | 10:11 AM
gask99's Avatar
gask99
Default heater light..
Thanks for the reply.....I do not have AC. If I remember correctly, the clock sits in it's own little housing. So... this would clip to the bottom of that housing?
Tom
Old Mar 17, 2008 | 10:25 AM
62Jeff's Avatar
62Jeff
Tom
Yes, the clock assembly fits into a housing that has part of the dash assembly. The bulb clips to the bottom of that housing.
JohnZ posted a picture a while back, but I'm having trouble finding it right now, and I'm heading off to the office for the day so I'll look again tonight if it hasn't been added to this thread by then.
Old Mar 17, 2008 | 10:31 AM
gask99's Avatar
gask99
Default Heater Indicator......
Thanks for your help !!!
Old Mar 17, 2008 | 12:14 PM
JohnZ's Avatar
JohnZ
Here's the photo of the "torpedo lamp" that clips into the clock housing at the 6 o'clock position; note that it won't work unless the clock is installed and connected - the lamp gets its ground from the upturned end of its retaining clip contacting the outside of the clock case.
Old Mar 17, 2008 | 05:04 PM
gask99's Avatar
gask99
Default Lamp
Thanks to everybody. Makes sense now.
Tom
Old Mar 17, 2008 | 05:19 PM
gask99's Avatar
gask99
Default One more question......
My light tube has a "green cap" on the end of it. Is this right? Keep it on?
Old Mar 17, 2008 | 06:51 PM
62Jeff's Avatar
62Jeff
Yep. Causes a green-ish back-lighting to come through the heater/radio lettering, instead of a boring white light.
Old Mar 17, 2008 | 08:06 PM
gask99's Avatar
gask99
Default lamp...
Thanks, you guys are the best.
Old Mar 17, 2008 | 09:02 PM
C2Driver's Avatar
C2Driver
John, if only I had thought to take pics like that when disassembling things on the Vette, I'd save my self a lot of time the second time around! Thanks for the pic. I've saved it for future reference. - Pat
To Heater Indicator Light
