Help with PCV system
If you have breather holes in both rocker arm covers, you don't need one from the back of the block. The 2 rocker arm cover holes are waht Chevy used in late 60s, 70s, and into the 80s. Look at how Chevy plumbed the PCV system for these cars.
George.
Driver during the week and a road race track day car a couple times each year. The theme of the car is keeping with it's racing background.
I think the question you may be asking is: What parts am I missing for a basically stock looking configuration.
My 65 327/350 has the following:
1) Metal tube that bolts to the top of the block, in that big hole you see next to the distributor hold. That metal tube isn't very long, and has a large diameter rubber hose that connects the tube, to a large fitting on the bottom of the air cleaner
2) An oil fill tube with a metal fitting on the side
3) A metered orifice fitting in the side of my Holley 2810 carb
4) A rubber hose joining the metal fitting in the oil fill tube, to the metered orifice in the side of the carb.
This photo shows all 4 pieces, but for the air cleaner.
It doesn't matter whether the flow goes in or out that hole in the block. You just have to have a vacuum source with a pcv valve or restrictor fitting plumbed in one end of your crankcase and clean filtered air on the other end or side feeding the draw of the vacuum.
I have no idea what you need for your racing needs. If you have a lot of blowby and you're pretty fast on the track, your engine will probably overload the pcv system and start blowing oil out somewhere.
I wouldn't keep what you have in any case. You'll have oil vapor everywhere and not an effective system to draw out moisture and contaminants in your crankcase .
Roger, can you help us out by telling us what your real goal is, and what year of car you are working on?
All the missing parts had me confused, and the thought of oil blow by all over the place brought me to ask advice from the forum folks. My main concern is whether the system needs to have a vaccum source, or just a big catch can for the three breather sources.
Bill
From there, there were various configurations, BUT, all of them included SOME KIND of inlet (breather cap on the oil filler tube plumbing from the air cleaner) air for the crankcase and SOME KIND of outlet for the crankcase. All engines still have this setup in some form or fashon-----------------ALL of them!
Up through 62 (EXCEPT Calif), all engines had a road draft tube. I can only guess, but I presume you know what a road draft tube looks like (if not, I'll show you a picture). The road draft tube was attached to the hole in the rear of the block with a long 1/4in bolt like the one in the below picture. The bolt had a small washer and a seal, as you can see.
Beginning in 63 to 67, there were multiple configurations of positive crankcase ventilation (PCV). Except for Calif cars in 62, all engines got a PCV valve in 63-up. And this was done in several ways (the road draft tube was gone forever). Many engines used the vent hole adapter and long bolt (below) with a hose connected to the adapter and then connected to a PCV valve at the base of the carb. Some engines had various shapes of tubes connected to the vent hole which went to the base of the air cleaner and another hose connected to a fitting and/or PCV valve at the oil filler tube. As already mentioned, inlet air could either come into the oil filler tube and be sucked out of the rear vent hole or vice versa. It all depended on the configuration of the engine/carb/FI setup.
The 2nd and 3rd pictures are the PCV setup for a 63 FI car (customer's car). There was simply a rubber gormmet with a tube in it that was pressed into the rear vent hole, then it snaked under the distributor and connected to a PCV valve that screwed into the side of the FI plenum. Inlet air came from the air cleaner over to the oil filler tube. The 64-65 FI engines reversed this PCV routing. Inlet air went into the rear vent hole and was sucked out through the oil filler tube into the FI plenum.
Bottom line, fresh air into the crankcase (SOMEWHERE) and vapors (dirty air) sucked out into the carb or FI (YUK!!!!).
By the way, it's your car, your money and you have the right to do anything you please with it and NO ONE should criticize you. BUT, it sure hurts me to see holes cut into the finned alum Corvette script valve covers.
If by chance those are no-line valve covers, and they were mine, I would locate a person who is an EXCELLENT alum welder, have the holes welded, grind down the weld and finish it smooth and install the covers with the repair toward the rear.
As for the valve covers, the rules for the time required extra breathing and for it to be captured. The hole saw was the answer. I hope to repair them in the future but for now I will make them work. Out of the things that could have been done to this car for the racing stuff, this is probably the only butcher job I can think of.
