How do I mesure off-set
Old Mar 21, 2008 | 04:13 PM
BuffaloBILL's Avatar
BuffaloBILL
Default How do I mesure off-set
Hello
My buddy who is doing a resto-mod on his 68 C3 coupe having mild flares installed on all 4 corner's (wheel wells) He is having 18X12 Custum wheels built but needs to measure off set to clear e-brake
How does one measure the offset needed?
May be a silly question
Happy Easter
Bill
Old Mar 21, 2008 | 06:12 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
i THINK you mean 'backspace', not offset. if so, measure from the face of the axle hub (the surface the wheel bolts to) to the closest part on the trailing arm (or other close parts) at about a distance of 8 inches from the center of the hub (use a straight-edge to lay against the face of the hub, then move outward from the center and measure the closest points in the 8 to 10 radius inch range from the straight-dge to the closest point)
bear in mind that this measurement is the backspacing that the RIM will hit the closest point; if the tire sidewall extends beyond the width of the rim, then the tire will hit something before the rim will, soooo, you have to decide on a tire size, then determine the section width (widest part of the tire) and use that in combination with the wheel width to figure out the maximum wheel backspacing (with a tire mounted) that will give sufficient clearance...
clear as mud, huh?
Bill
Old Mar 21, 2008 | 06:27 PM
Nev Williams's Avatar
Nev Williams
Originally Posted by BuffaloBILL
Hello
Happy Easter
Bill
This drawing may help. The 102 dim is backspace. The one above is offset
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
There are actually TWO different types of measurements that characterize a wheel....offset and back space.
Backspace - the distance from the mounting face of the wheel to the BACK of the wheel lip
Offset - the distance that the mounting face is from the "center" of the wheel.
It is much easier to measure backspace since all you do is lay a straight edge across the back of the wheel and measure down to the mounting face. BUT, in order to figure out where the tire will be, you need to know where the center of the tire is relative to the mounting face, hence the need to know where the offset is. Once you know that you have a pretty good idea where the edge of the tire will fall.
After you do all the calculating, I would leave an extra 1/4" of clearance for the tire "just in case" on both sides. Crap happens
This link will answer any questions you have on wheels....
https://rsracing.com/tech-wheel.html
good luck, Herb
Old Mar 21, 2008 | 06:42 PM
Kensmith's Avatar
Kensmith
Go here: https://www.rsracing.com/tech-wheel.html
Old Apr 6, 2021 | 08:09 PM
63 340HP's Avatar
63 340HP
I found some photos that may help.
Rim width is measured at the bead seats (8" rim in photo).
Backspace is measured from the rim center that mates to the brake hub, to the edge of the inner rim flange (4 3/4" backspace in photo).
Old Apr 6, 2021 | 09:01 PM
SWCDuke's Avatar
SWCDuke
This thread is 13 yiears old.
Duke
Old Apr 6, 2021 | 09:05 PM
63 340HP's Avatar
63 340HP
Duke
.. and the descriptive photos disappeared... (fixed)
Old Apr 7, 2021 | 10:48 AM
vettebuyer6369's Avatar
vettebuyer6369
This response is to a post from 13 years ago.
To How do I mesure off-set
