I purchased a New Dewitt direct fit back in the summer at Carlisle. If I painted it would it decrease its efficiency ??
What brand of paint would you recommend ?
I see some fan kits that mount directly to the core with plastic ties.
Could this type of mounting damage the radiator??
All your opinions are appreciated.
Peter
don't know about paint (methinks Deer Blitz Black would do ya) but your question about mounting aux fans caught my attention - why, is you car running hot with the Dewitts rad and a proper fan on a working fan clutch?
The correct color is Gloss Black. A light coating should not effect function. There is also available through the usual corvette mags the correct Harrison foil decal that attaches to the top right side.
The fans are attached with zip ties, but they are a special type. They have a large circle at one end, and the slide lock is also a circle. There is also square foam pads that go between the zip tie circle ends and the radiator core.
Unless you have some exotic set up, I would stick with the stock clutch fan. JMO.
PS, when you install the radiator, make sure the rubber bushing on the bottom and top are in good shape, and the shroud does not touch the radiator. If it touches it may cause a vibration or cause an unwanted electrical ground.
The car has a 300hp motor with Edelbrock cam, carb and intake.
The rad is copper with aux fan .It does not have a clutch fan but does have a flex fan. Fan shroud is not right either.
During hot summer days 85F plus it would run in the 180-190 range while moving. During stop and go traffic it would run 210-220F and the fan would kick in and keep it from over- heating.
Also had hard start problems from heat soak. I will use a spacer under the carb. Big discussion on fuel quality and ethenol %.
I'm replacing the fan shroud as well with the proper 63-65 . Do you think I need the electric aux fan ?? I would rather not use the aux fan .
I purchased one late in the season last year. I went for one hour drive in late october 65F. I let the car heat soak for 10min. in the garage and check for temps with IR gun. I found the carb to be about 145F the top rad hose close to thermostat housing around 190F but found the fuel filter that is mounted at the front of the motor by the head was 195F .
I need to have warmer ambient temps for the heat soak problems to appear. One time it took about 10 cranks before it started and stumbled for 45sec. I had to keep my foot on the accelerator to keep it from stalling, It did clear but it was about 100f that afternoon.
Good, you've got an IR gun. Often folks get misled by the Temp Gauge on their dash, which is telling them the lies that a bogus temp sender is sending.
A solution to the carb heat problem is to remove the intake and install an intake gasket with the heat passage block off plates. This of course assuming you do not drive your car in cold weather. I see that you are in Canada, so that may be a problem if you drive your car in late fall and over the winter.
The copper radiator is the problem with the over heating issue. The new radiator will fix that. I would toss that flex fan in the trash and get a stock 5 blade fan and a clutch for it. The correct shrouds are available as well.
This combo with a stock motor will be all that you ever need. Remember that 190-200 is normal. The T-stat (If a 180) only begins to open at 180.
I purchased a New Dewitt direct fit back in the summer at Carlisle. If I painted it would it decrease its efficiency ?? What brand of paint would you recommend ?
Peter
Just so everyone knows what you got, the "Direct Fit" model is our replacement aluminum version and not the original plate type we call "Restoration". The Direct Fit is a very good radiator (4100 btu) and far better than the copper replacements (3290 btu) but it still is slightly less than the restoration model (4600 btu).
Painting the Direct Fit is NOT going to affect the cooling however, not many paints will stick to the aluminum, in fact, I only know of one. The special two part epoxy that we use bonds real well. We have never sold this paint before but if there is a demand we would consider it. Keep in mind, we do offer a painting service (#333) for $30.
I do not recommend the zip ties for mounting fans! Aluminum is a pretty soft material and the cooling tubes are only .017" thick. Hanging a fan on the cooling tubes will eventually wear a hole in the tube. That's why all the fan mountings we offer use solid metal brackets of somekind.
You can get the Direct Fit model with a fan already mounting by ordering SP016 (63-72) or you can order that add-on kit SP004. http://www.dewitts.com/pages/product...asp?ProdID=322
2016 C2 of Year
2015 C3 of Year Finalist
Not what you may want to hear, but if it were my car I would consider dumping/trading the copper radiator for one of Tom's aluminum radiators. I bought one for my 65 and it runs 180 all day long in summer heat on the open road or in traffic with a stock clutch fan. Why be bothered with all the hocus pocus auxilliary fans? Copper radiators simply don't transfer heat as well as aluminum. On days when the temps are over 70 degrees you will run too warm.
I see Tom posted as I was. I guess it's not copper/brass. Still don't like all the electric fans unless you NEED them for a radical motor.
Reason: Tom's pos
Mark
A grounded radiator is not a problem, as long as you do not have an electrical short somewhere that would cause electrolysis. If you look at the way the 55-60 radiators are mounted, they are steel flange mounted, fully grounded to the frame. The original radiator was copper but thousands of aluminum radiators have taken their place without any problems. Another, maybe stronger case, to suport this theory is the 61-62 cars had aluminum expansion tanks mounted directly to the motor with metal brackets and zero insulation.
Install Dewitt direct fit unpainted (Tom would por15 work?)
locate and install clutch fan
Install correct 63-65 fan shroud with lower seal
Block cross over under intake manifold (This may have been done already)
install carb insulator 5/16 ", and use drop down base air filter and bango style fuel line as Paul 67 has done. Also change fuel filter position to on top of intake manifold ?
I have read in other posts about a sacrificial electrode. What is this and should I use it ??
It might, I just haven't used it before. The biggest problem with all the paints is the new aluminum is very smooth and nothing sticks real well. If you really want the radiator black, I'd rough it up a little with a scotch bright pad on the top surface and the end tanks.
It sounds to me if i go back as close to stock configuration as possible that most of my cooling problems will disappear.
Thanks a bunch !!
Well, if you go back to a stock configuration, then any cooling problems that remain are anomalies.
People throw lots of money at cooling problems after deviating from stock. If the engine is basically stock (as in your case) then the stock cooling system should be ok if everything is working properly.
That having been said, my cooling system is completely stock, including a new DeWitt's restoration radiator. I have factory A/C, and have seen temps close to 200 in the middle of summer, stuck in traffic, with the A/C on. That that's not what I'd call a cooling problem.
