Info from VIN
Old Mar 21, 2008 | 10:40 PM
mike gleason's Avatar
mike gleason
Default Info from VIN
Is there a place to run the VIN to find out when and where the vehicle was orginally purchased from GM as well as the original specs etc???
Old Mar 21, 2008 | 10:43 PM
62Jeff's Avatar
62Jeff
Welcome.
For what year?
For the 53-67 - there isn't enough info in the VIN to learn anything other than the build sequence, and coupe or convertible (63-67 only).
Old Mar 21, 2008 | 11:16 PM
ricks327's Avatar
ricks327
In the C1 or C2 forum, a quick answer to your question is NO.
Old Mar 21, 2008 | 11:32 PM
buns's Avatar
buns
Actually, if you have any reason to believe that your car was originally sold in Canada, then you can get this information from GM ( of Canada ). If not, you are SOL.
Old Mar 21, 2008 | 11:52 PM
Illinicane's Avatar
Illinicane
St. Jude Donor '06
This will give you limited information. Not sure if this is what you were looking for.
http://www.corvettelink.com/vindecoder.asp
Old Mar 22, 2008 | 02:19 AM
mike gleason
It is a 65 Conv, I have had it since May of 72.
Old Mar 22, 2008 | 02:38 AM
Fawndeuce's Avatar
Fawndeuce
Check the data plate for more info, it is mounted right beside the VIN plate.
Paul
Old Mar 22, 2008 | 03:27 AM
Rob Musquetier's Avatar
Rob Musquetier
You can derive the app. birthday of the car by using the birthday calculator on the C1, C2 and C3 Registries.
greetings,
Rob.
Old Mar 22, 2008 | 10:56 AM
5thvet's Avatar
5thvet
Paul
You can figure out the original color, interior color and type ( leather etc), which plant the car was assembled . The rest you are sol except looking on the front pad to verify the engine is orginal and you can tell the original set up ie. 327-300HP, auto or 3 or 4 speed.
Old Mar 22, 2008 | 11:00 AM
Rob Musquetier
Paul
This onlly applies to 63 and + cars...
Old Mar 22, 2008 | 11:06 AM
5thvet's Avatar
5thvet
I think he posted it is a 65 Vert
To Info from VIN
