window felt
Old Mar 22, 2008 | 02:03 PM
gtjr's Avatar
gtjr
Default window felt
On my 67 convertible how do i change the rear window felt? My felt has worn down to the steel. As i roll the window up and down i can feel it rub . Also who has the right one for my car? THANKS George
Old Mar 22, 2008 | 02:17 PM
ren's Avatar
ren
I ordered replacement felts from Wilcox. I don't know how to pull out the old and put in the new. Actually, I dropped the car off at a custom window shop this morning. I'm getting the outer whiskers and some of the channel stops replaced too. Good luck.
Old Mar 22, 2008 | 02:28 PM
62Jeff's Avatar
62Jeff
If this is the window felts that are in the rear, vertical window channel inside the door- those are just glued in place.
Old Mar 23, 2008 | 07:42 PM
ratpack1968's Avatar
ratpack1968
Replacement felts are available at any of the major suppliers for about $3. To do the job right you will need to pull the rear channel from the door and scrape out the old felt and adhesive using 3M or similar adhesive remover. Then simply glue in place the new felt and trim off excess. The hardest part is reinstalling and making the proper adjustments for smooth operation of the glass.
The front channel is really fun. You will need to pull the entire vent window assembly and rivet the channel into place. The fun part is trying to finesse the repop channel into place.
To window felt
