Paging Roy Braatz:
I just purchased a copy of your Powerglide video from your brother-in-law (Glassman) and watched all two hours of it last night in 6.1 digital surround (my wife thinks I'm nuts).
In spite of your opening remarks and apologies I think it was very well done. I would rename it "Powerglide for Dummies Like Me."
I purchased a rebuild kit a year ago and it came with the "banana gasket" with the built-in O-rings like you suggested, but it did not come with any seals, steel clips or anything else beyond just gaskets. Do you have a preference on a complete kit and who do you get it from?
By the way, the video was $49.95 delivered. I've worked on manual transmiisions and B&J Racing planetary transmissions but never an automotive automatic. Because of Roy's video I will be rebuilding my first Powerglide myself and I'm looking forward to it.
With the $1,800.00 I'm going to save I may take my wife out to a nice dinner.
RG
RG
It don't cover everything just a simple rebuild which most trans need. It is crazy how much money a shop gets to restore one when it's so simple and the kit cost so little. You see the over haul kits on e-bay or a guy's add in the NCRS drive line mag. Thanks for the nice comment !!
I checked out the date code numbers on the tranny. E-4-4 for the bellhousing and E-5-4 for the tranny section. One day apart. Now the bad news (which I discovered last night). The ear for the starter on the bellhousing section is cracked at the bellhousing section. Is this a common problem? A friend of mine has access to an excellent cast iron welder in the Redding area. Would you weld it or find another one? I hate to break up the pair since the dates are so close.
Here's me in the '57 driving into the John Force Christmas Car Show last year. I'm going to be selling it. It is an NCRS regional Top Flight car that runs like a champ but I'm scared to death to drive it so it sits with two car covers on it 99.9% of the time. The 1954, however, is going to be driven a LOT:
That's the problem of restoring a Corvette ,then people are afraid to drive them , I understand that. But as soon as I restore my Corvettes I cant wait to drive them ,one week after doing our 55 Corvette we took a tripe to NY, and still drive it 30 years later and still got a top flight in 05.
By the way I have 20K to buy your
I've been all over the tranny with lights and mirrors as the transmission is still in the car. As far as I can see it's just the ear that's cracked. When we got it two years ago it was a working/driving 12V car. I am in the middle of converting it back to 6V because I want it to be as original.
The '57 can be seen on the registry at:
http://www.c1registry.com/index.php?...04-16&uid=2917
Randy
Regarding my 1955 original Corvette VIN 18 :What do the metal rings on the ends of the spark plug mesh shielding attach to ? How does the rear of the bubble top attach to the body ?
Ray DeCesare
there are four points that they are screwed to the Dist shielding grounding them
1 the ground shielding is to close to each end of the rubber boots causing the plug boots to start shorting when the rubber boots get hard from the engine heat
2 the inner wire is made of Carbon which will burn and not carry a true 12V using the older coils
After years of driving my 55 and replacing the wires three times at over $150 a set I realized the problem/// just using their shielding I replaced the wire , used 7 mill. wires having STEEL wire cord not CARBON also keeping the shielding 1inch back from the rubber boots .
OK now you can believe me (or) and what I did, which makes the engine run so great with more HP and no missing after years or keep them as they are if your a trailer queen
You can call me if you have problems installing the shielding at 530-265-2756
Again why dont they repro things RIGHT
